65 Satellite belt molding trim clips?? #1685757
10/14/14 03:20 PM
10/14/14 03:20 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I just parted out a 65 Satellite and a while back a 65 Coronet. On the doors and the 1/4 panels where the narrow trim clips on below the stainless trim at the top of the door and 1/4 panel are these the correct clips that were used? Are they available aftermarket anywhere?
I see the trim clips for a 68-70 B Body vinyl top trim are nearly identical.
Can anyone confirm the total needed to do both doors and 1/4 panels? (I think I count 26)
I have a guy who wants a set and I may have trouble coming up with a complete set.
Edited to say Satellite instead of Coronet.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685758
10/14/14 05:09 PM
10/14/14 05:09 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Picture of clip in question.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685759
10/14/14 05:28 PM
10/14/14 05:28 PM
The Scratch, WA
P
Part_Stalker Offline
P
The Scratch, WA
Those clips are not for the trim on a Satellite, at least any I have seen. My Satellite trim is held on by little rectangular plastic clips that have a dowel in the center. I haven't seen any aftermarket variations either but am going to use some off a 63 Fury as they looked identical but were a different color. Figured that out staring at it in the garage next to my 63. Luckily I had a buddy who was parting out a 4 door Fury and I snagged what I could. They have a tendency to deteriorate in the sun. Those rocker molding clips are another story by themselves. As far as how many, I would have to go home and count the holes.
Re: 65 Coronet belt molding trim clips?? [Re: Part_Stalker] #1685760
10/14/14 07:50 PM
10/14/14 07:50 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
When I parted out the Coronet it had never been painted so I assumed it had never been apart. The Satellite I just pulled apart was painted years and years ago and had these clips. Did they use both types or has someone changed these out on two separate cars?? Ist car came out of NY and the other about 70 mile away. I think I have an old Satellite door in storage. maybe I can go see what it has. Could it be a Plymouth or Dodge thing?
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685761
10/14/14 09:19 PM
10/14/14 09:19 PM
The Scratch, WA
P
P
The Scratch, WA
It very well could be a Dodge vs Plymouth thing. The lady at the Auto body store suggested I try their generic clips like the one you had posted. So I supposed if someone had pulled the trim to paint it they could have used those. Or in my case when most of the trim was in the trunk you are left to fend for clips and screws. I also noticed you edited your original posting. Didn't it say Coronet 440 before? I have a few 65 500's with the skinnier trim I can check to see what fasteners they use for the those. Pretty sure I tossed most of my 440 trim last month.
Re: 65 Coronet belt molding trim clips?? [Re: Part_Stalker] #1685762
10/14/14 11:26 PM
10/14/14 11:26 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I had it as Coronet 440 but I looked at the 440 in the garage and it only has the top trim (belt molding) which does use the clips like pictured only a different width.
I was thinking it was a 440 model that had the trim the same as a Satellite.
Ultimately what I am looking for is whatever clips would be used to install the belt molding trim on a 65 Satellite.
I pulled out a few different pieces of Satellite trim I have here and two sets used the steel clips while one piece had the plastic clip still in it? I will post pics of those tomorrow.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685763
10/15/14 12:43 AM
10/15/14 12:43 AM
The Scratch, WA
P
P
The Scratch, WA
Please do post pictures as I would like to see them. It took me awhile to gather mine as they break pretty easy. I checked all my sets and didn't find any with metal clips. And I counted 11 per side assuming I had the right holes.
Re: 65 Coronet belt molding trim clips?? [Re: Part_Stalker] #1685764
10/15/14 03:09 AM
10/15/14 03:09 AM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I have a 65 satellite and parted out 2 others
My car had the wire clips , 1 car I parted out had wire clips and 1 car had the plastic clips
My car has been apart since 1989 so I don't remember the quantity needed
Rocker moulding clips.. I have talked to many clip guys and numerous NOS part dealers about these - Most feel they were only available as a set with the mouldings - not as replacements
Talked to Joe Suchy at the nats this year.. He said they may reproduce the rocker molding clips
Re: 65 Coronet belt molding trim clips?? [Re: SSAAHemiFan] #1685765
10/15/14 08:53 AM
10/15/14 08:53 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
That's what I found also. Here are the pics of it both ways.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685766
10/15/14 08:55 AM
10/15/14 08:55 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
metal clip
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685767
10/15/14 08:55 AM
10/15/14 08:55 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
plastic
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685768
10/15/14 08:57 AM
10/15/14 08:57 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
face of trim
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685769
10/15/14 09:00 AM
10/15/14 09:00 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I did find one of these clips that is different from the rest. It goes directly under the rear roof post at the wide area of the trim.
This is almost enough to make me glad mine is a Bel II.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685770
10/15/14 12:49 PM
10/15/14 12:49 PM
The Scratch, WA
P
P
The Scratch, WA
Interesting. I wonder if the clips were done different by plant? I learned something new today. I also forgot about that big clip at the back. There is a guy on eBay that produces clips for the rocker molding but they are different than the factory ones and require drilling new holes. I think his name is 65Satelliteman on there. He is the one who reproduces the grill emblems also. It would seem you should have less problem finding those metal clips than the plastic ones.
Re: 65 Coronet belt molding trim clips?? [Re: Part_Stalker] #1685771
10/15/14 01:04 PM
10/15/14 01:04 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I have purchased a few things from him in the past and always got very nice stuff.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685772
11/06/14 07:02 PM
11/06/14 07:02 PM
Ontario Canada
3
300_dup5 Offline
300_dup5  Offline
Ontario Canada
Just got some Parts from Skicker nice guy Helped me out with some small stuff for my 65 Satelitte, Those Belt moulding clips, Skicker sent me one of the steel ones( yes some had plastic, some steel, matched them up with 68-70 b body vinyl trim clips, almost identical
Re: 65 Coronet belt molding trim clips?? [Re: 300_dup5] #1685773
11/07/14 10:29 AM
11/07/14 10:29 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Glad you got it figured out.
Work out all the bugs on yours, then once you know how everything goes back together you can come down and do mine.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685774
11/07/14 01:59 PM
11/07/14 01:59 PM
The Scratch, WA
P
P
The Scratch, WA
So am I hearing something about house calls? So Terry are the 68-70 vinyl top trim clips available aftermarket? I would love to use something more sturdy than 50 year old plastic clips on mine.
Re: 65 Coronet belt molding trim clips?? [Re: Part_Stalker] #1685775
11/07/14 03:54 PM
11/07/14 03:54 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
After a quick Google search it appears they're available pretty commonly. Herbs, RT specialties, Hoover, Jim's and several others were listed. Being as that you need more than what a regular 68-70 kit has you may find someone who is willing to sell you a "lot" of them. I think the total count needed is 22 or 24. That's what this whole post was about in the beginning.
...FAFO...
Re: 65 Coronet belt molding trim clips?? [Re: skicker] #1685776
11/07/14 07:00 PM
11/07/14 07:00 PM
Ontario Canada
3
300_dup5 Offline
300_dup5  Offline
Ontario Canada
Got mine from Dante,s, Hey Quint, I'll do a tour down your way sometime,I'll send more pics of my progress, Don't forget the pics of the glass moulding mount locates for me
