Filter first or not?
#1685411
10/13/14 10:57 PM
10/13/14 10:57 PM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
When setting up an electric fuel pump do you want to have the filter after the pump or before the pump? I am assuming after but.. I have assumed before! Thanks.
RS23L7 4-Speed
Re: Filter first or not?
[Re: Mopar_Mike]
#1685412
10/13/14 10:58 PM
10/13/14 10:58 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Mine is set up filter first.
[Re: Cab_Burge]
#1685414
10/13/14 11:45 PM
10/13/14 11:45 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I roasted 2 edelbrock fuel pumps with filter in front. Third time I went with new brand (Holley) and no filter other than sock in tank,, never another problem.
Plastic tank with no rust to worry about. Right or wrong, just my expierence.
**Photobucket sucks**
[Re: 70Cuda383]
#1685417
10/14/14 02:57 PM
10/14/14 02:57 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
I would have a field day with Edlebrocks quality control people, roasting two pumps because of using a fuel fliter is ridiculus I don't worry about the debris created in the tank in my cars, I worry about the debris coming out of the fuel truck that delivers the fuel and then the debris in the underground storage tanks and so on Lots of gremlins out there, Murphy has bit me more than once on debris in the needles and seats at the race track and on the street when I ran no fuel filters ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: Cab_Burge]
#1685418
10/14/14 03:54 PM
10/14/14 03:54 PM
Posts: 11,743 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Filter before the pump. Make sure the filter and plumbing from the tank to the pump will flow enough to not allow any cavitation.
I use a paint strainer in the funnel I use to put fuel in the cell. And I'm anal about keeping the jugs clean. Keeping crap out of the system to begin with is most of the battle.
[Re: CMcAllister]
#1685419
10/14/14 04:03 PM
10/14/14 04:03 PM
Posts: 13,407 Marion, South Carolina [><]
an8sec70cuda
![](/ubbthreads/images/graemlins/iagree.gif)
[Re: an8sec70cuda]
#1685421
10/14/14 04:15 PM
10/14/14 04:15 PM
Posts: 34,964 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I talked to Aeromotives head of tech and he told me to never pre-filter his pumps Explained to me as like laying a coke bottle on its side and you see the bubble, that will cause Cavitation And it burn out the pump ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: bigdad]
#1685422
10/14/14 04:25 PM
10/14/14 04:25 PM
Challenger 1
Cincinnati, Ohio
And he would be right imo, but everyone one wants a bit of insurance for there expensive pumps.
I never used any strainer from the fuel cell to the pump on any belt driven mechanical pumps I have raced with. Never liked electric. We strained the fuel in the funnel as we fill the fuel cell. We also go to great pains to keep the fuel clean, like replacing our fuel jugs every 2 years because the methanol will lift little pieces of plastic from the inside after extended storage. So we started putting the methanol back in the steel drum and storing our plastic fuel jugs empty during the off season. Then used a outlet filter on our NA injected motors and no filters at all on our TAD screw blown hemis because filters strainers interrupt fuel flow.
But on the other hand, this can happen without filters. One plugged nozzle with anything can torch a block, sleeve, head, headgasket and piston. It makes a mess of things behind the motor too, like burns off the parachutes, trans safety blanket and all the wiring. Here's what a piston looks like if the nozzle get's restricted under 60PSI of boost.
[Re: bigdad]
#1685424
10/14/14 08:13 PM
10/14/14 08:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
EVERY electric fuel pump has a pre-filter in ALL production cars... and we worry about warranty more than any company... I run tree catcher(100 micron) filters before all my pumps and if its injected it gets a 10 micron filter after the pump... you CANT choke a pump with a small filter(thats micron and size) along with the pre pump hose... the pump creates the negative pressure so the atmospheric pressure can PUSH in the fuel ![](/ubbthreads/images/graemlins/wave.gif)
[Re: bigdad]
#1685425
10/14/14 08:39 PM
10/14/14 08:39 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not saying he's wrong, but that's the first I've heard that. Another consideration to help prevent anything like this is to always mount the pump so that the pump inlet and plumbing from the tank to the pump are below the level of the fuel in the tank. Gravity will keep the inlet side full rather than relying on the pump to lift it.
