Anyone use Brad Penn moly ep2 on cam lobes #1684384
10/10/14 10:10 PM
10/10/14 10:10 PM
Western PA
O
OldMoparMan Offline OP
O
Western PA
I'm getting ready to assemble another motor and was wondering if anyone has used the Brad Penn moly grease on there camshafts and if so did it cling well the surface on the lobes.
Living with ALS help support the search for a cure
Thanks http://web.alsa.org/site/TR/Walks/WesternPennsylvania?team_id=347781&pg=team&fr_id=12069
Re: Anyone use Brad Penn moly ep2 on cam lobes [Re: OldMoparMan] #1684385
10/10/14 10:40 PM
10/10/14 10:40 PM
Is this BP's moly grease that they have available for general extreme pressure use and or is it intended for lobes? I am a fan of their "green" oil.
Re: Anyone use Brad Penn moly ep2 on cam lobes [Re: OldMoparMan] #1684386
10/11/14 01:26 AM
10/11/14 01:26 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
What Dwayne Porter recommended that I use when I install my new flat tappet cam in my Hemi is Joe Gibbs Driven Assembly Grease part number 00732.
He said it stays on the lobes and doesn't drain off if you don't fire the engine right away.
He also recommended using Joe Gibbs break in oil too for the cam break in.
The assembly grease.
http://joegibbsdriven.carshopinc.com/product_info.php/products_id/105676/00732
Re: Anyone use Brad Penn moly ep2 on cam lobes [Re: SNK-EYZ] #1684387
10/13/14 12:35 AM
10/13/14 12:35 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
We use EP0, EP1, and EP2 (mostly Mobil) on our Turret press at work.
Good stuff, but not sure if it is the best for cam break in..
Re: Anyone use Brad Penn moly ep2 on cam lobes [Re: SNK-EYZ] #1684388
10/13/14 12:42 AM
10/13/14 12:42 AM
SW MO
closer9 Offline
closer9  Offline
SW MO
That's what Hughes recommended and what I used. (actually, seems like it came with the cam) Worked well for me...
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: Anyone use Brad Penn moly ep2 on cam lobes [Re: OldMoparMan] #1684389
10/13/14 08:28 PM
10/13/14 08:28 PM
Western PA
O
O
Western PA
I ordered a tub of Joe Gibbs.
Thanks Guys
