Re: Who has a rotary A/C compressor on there Big Block?
[Re: GLR]
#1684258
10/10/14 09:43 PM
10/10/14 09:43 PM
Challenger 1
Cincinnati, Ohio
Gary, Yea..I think I will "try" to run mine the same as the factory did it in 1971, were the one line/hose comes from the conection at the firewall to the pump, then the other line goes from the pump to the condencer on the drivers side. My only concern is will it interfere with my air cleaner assembly? I will have a 383 with a 6-pack and a normal B-body factory six pack air cleaner assembly. I am thinking I will try to have the pump conections on top.
I felt the same way at first, at least go the stock route. But it was way cheaper, easier to do it with hose and felt it would be too much hose to run all the way across the front with rubber hose if I split them. Plus up top like that I didn't have any other option. Then you need custom made steel or aluminum lines(nice) if I split them side to side. I'm sure it's not best or don't look stock or even close. My car is just a driver and it works well.
