Re: Who has a rotary A/C compressor on there Big Block? [Re: GLR] #1684258
10/10/14 09:43 PM
10/10/14 09:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Gary,
Yea..I think I will "try" to run mine the same as the factory did it in 1971, were the one line/hose comes from the conection at the firewall to the pump, then the other line goes from the pump to the condencer on the drivers side. My only concern is will it interfere with my air cleaner assembly? I will have a 383 with a 6-pack and a normal B-body factory six pack air cleaner assembly. I am thinking I will try to have the pump conections on top.
I felt the same way at first, at least go the stock route. But it was way cheaper, easier to do it with hose and felt it would be too much hose to run all the way across the front with rubber hose if I split them. Plus up top like that I didn't have any other option. Then you need custom made steel or aluminum lines(nice) if I split them side to side. I'm sure it's not best or don't look stock or even close. My car is just a driver and it works well.
Re: Who has a rotary A/C compressor on there Big Block? [Re: Challenger 1] #1684259
10/11/14 11:34 AM
10/11/14 11:34 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I guess I should ask if all the brackets that are made to mount the sanden pump on to a Big Block Mopar are the same or if some are a little lower than others? I haven't purchased them yet, but I have a 440 source aluminum water pump housing with a passenger side lower hose connection that I will be using. I saw pictures of the brackets that Classic Auto Air..sells and they use aluminum brackets and the back side uses a tiny block that bolts to the head and the back bolt on the pump bolts to it. The bouchillon brackets are steel (I think) and don't use the bolt hole on the engine head to mount, they have a back bracket that mounts to the water pump. Anyone know which bracket mounting system keeps the pump lower/closer to the block?
Re: Who has a rotary A/C compressor on there Big Block? [Re: GLR] #1684260
10/11/14 01:52 PM
10/11/14 01:52 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Gary,these are Buchillon brackets,doubt there is anything else that would sit closer,only about 1/2" between the compressor and water pump housing and still easy to access all mounting hardware.
Re: Who has a rotary A/C compressor on there Big Block? [Re: 62maxwgn] #1684261
10/11/14 02:13 PM
10/11/14 02:13 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
What part number did you get? I have an aluminum water pump housing-(440source) copy of the 74-up Big block housing that has the passenger side lower hose conection.
There is a BPE4700
and a .....BPE4710
Re: Who has a rotary A/C compressor on there Big Block? [Re: GLR] #1684262
10/12/14 09:56 AM
10/12/14 09:56 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Both A/C hoses on my car exit the toward the dist...
https://board.moparts.org/ubbthreads/show...rue#Post7988764
Jess
Yeah, it's hopped up to over 160...
Re: Who has a rotary A/C compressor on there Big Block? [Re: jt4406] #1684263
10/12/14 09:58 AM
10/12/14 09:58 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
Another...
Re: Who has a rotary A/C compressor on there Big Block? [Re: jt4406] #1684264
10/12/14 10:41 AM
10/12/14 10:41 AM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Jess, THat is exactly what I needed to see! Thank you very much!... I also copied the link to your previous post about doing this. My engine compartment is the same as your E-body, so all will be the same except my car is a factory A/C car so I won't have to do the extra work at the firewall and I have an original style condencer.
Re: Who has a rotary A/C compressor on there Big Block? [Re: GLR] #1684265
10/12/14 12:50 PM
10/12/14 12:50 PM
Shoreline, Washington
72roadrunnergtx Offline
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Who has a rotary A/C compressor on there Big Block? [Re: 72roadrunnergtx] #1684266
10/12/14 07:35 PM
10/12/14 07:35 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Doug, Excellent picture, very nicely done! Thank you!
Gary
Re: Who has a rotary A/C compressor on there Big Block? [Re: GLR] #1684267
10/12/14 07:47 PM
10/12/14 07:47 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
Here's another view, not a rb exactly but shows the hose routing.
Re: Who has a rotary A/C compressor on there Big Block? [Re: CHRYCOFAN] #1684268
10/12/14 07:49 PM
10/12/14 07:49 PM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
With the aircleaner on. This was a Bouchillon kit also.
Butch
Re: Who has a rotary A/C compressor on there Big Block? [Re: CHRYCOFAN] #1684269
10/12/14 07:56 PM
10/12/14 07:56 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I like the 70-71 Sport Furys!..especially with a Hemi...nice ride! THanks for showing!
