Gen 3 Hemi oil leak #1683153
10/07/14 09:18 PM
10/07/14 09:18 PM
Orlando Florida
blown572dart Offline OP
Orlando Florida
First I should say hello to everyone.
Now to the question. I have a 5.7 that was stroked to a 6.4 with some head work and a cam. With that said after a small issue that required the pan to be removed I have been chasing an oil leak that's at the rear of the engine.
I can't believe that it's the oil pan gasket anymore. Has anyone had any issues with the gen3 leaking ?
Re: Gen 3 Hemi oil leak [Re: blown572dart] #1683154
10/07/14 09:46 PM
10/07/14 09:46 PM
Q
Quicktree Offline
Quicktree  Offline
Q
do you have a screw blower on it?
Re: Gen 3 Hemi oil leak [Re: Quicktree] #1683155
10/07/14 09:50 PM
10/07/14 09:50 PM
Orlando Florida
Orlando Florida
No but it is in my Jeep. ^^^^^^^
Re: Gen 3 Hemi oil leak [Re: blown572dart] #1683156
10/07/14 10:06 PM
10/07/14 10:06 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
There's a plate that goes over the crank at the rear. Maybe the rear one piece crank seal.
Re: Gen 3 Hemi oil leak [Re: MattW] #1683157
10/07/14 10:46 PM
10/07/14 10:46 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The rear main housing bolts to the block IIRC it becomes part or the pan rail like a BB does. It could be leaking at those seams. Also may be the flexplate bolts go clear through the crank flange and were not sealed. Don't know if this is a problem on these like some LS engine cranks.
Mopar to the bone!!!
Re: Gen 3 Hemi oil leak [Re: blown572dart] #1683158
10/08/14 12:17 AM
10/08/14 12:17 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Well go put it on THEN come back and ask us the question
I have no idea but if I can help let me know
