Aerospace brakes Good, Bad, Junk? #1682164
10/05/14 12:17 PM
10/05/14 12:17 PM
Menomonee Falls
DemonDust Offline OP
Menomonee Falls
Looking to get front discs on the Duster after last weekend at the strip. Trying to slow down from 136-138 mph with the front drums was a bit sketchy and I was spinning bad so it's gonna go faster.
Now I had a different thread where several guys said aerospace were some of the best on the market and one guy said several shops said they are junk don't even buy them.
So I want to hear your opinions on them have you ever used them? Had issues? No problems?
I can't imagine a company still in business if their product down right sucks.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Aerospace brakes Good, Bad, Junk? [Re: DemonDust] #1682165
10/05/14 12:35 PM
10/05/14 12:35 PM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
Jesse That what I have on my Duster front and rear and very happy with them.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: Aerospace brakes Good, Bad, Junk? [Re: 440W8 Duster] #1682166
10/05/14 01:51 PM
10/05/14 01:51 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I have them on the front and rear of my dart and love them.My brother runs them on his dart and really likes them to.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: Aerospace brakes Good, Bad, Junk? [Re: bdaz smblk] #1682167
10/05/14 02:23 PM
10/05/14 02:23 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
As I said in the other thread, ran the front for years and never an issue, new owner of car still has same set on, some 10 years now after I put them on.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Aerospace brakes Good, Bad, Junk? [Re: B3422W5] #1682168
10/05/14 02:29 PM
10/05/14 02:29 PM
Menomonee Falls
Menomonee Falls
No offense to you Don at all. I just wanted to make sure I was going the right way after I heard someone say several race shops said they were no good. I figured a thread with this brand specific would bring out anyone with hostility toward them and get more of an explanation than "race shops said so".
SDG Motorsports
Re: Aerospace brakes Good, Bad, Junk? [Re: DemonDust] #1682169
10/05/14 02:32 PM
10/05/14 02:32 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
Got them, no problems here
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Aerospace brakes Good, Bad, Junk? [Re: DemonDust] #1682170
10/05/14 02:44 PM
10/05/14 02:44 PM
NJ
cb1289 Offline
cb1289  Offline
NJ
We have Aerospace on 3 cars.
3800lb Supra, all 4 wheels, mid 9sec,145mph, street & strip,4yrs.
2800lb Pickup, fronts only, high 8sec,150mph, strip only,2yrs.
3700lb Dodge wagon, fronts only, mid 10sec, strip only, just installed this season.
No issues,easy install.
62 Dodge Dart Wagon 65 Plymouth Satellite
Re: Aerospace brakes Good, Bad, Junk? [Re: cb1289] #1682171
10/05/14 02:56 PM
10/05/14 02:56 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I had there front and rears on my car along with the master cylinder that they had in stock and they where great never an issue at all.
And I got great customer service as well, a year after my purchase I made some changes to the rear end and needed some more shims I made 1 call to them and they shipped me some shims that day at no charge.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Aerospace brakes Good, Bad, Junk? [Re: dusturbd340W5] #1682172
10/05/14 04:36 PM
10/05/14 04:36 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Have fronts on my car and are happy with them
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Aerospace brakes Good, Bad, Junk? [Re: 1967dartgt] #1682173
10/06/14 12:21 PM
10/06/14 12:21 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Been using them on my car 3350lbs mid 9's stops no problem
Re: Aerospace brakes Good, Bad, Junk? [Re: racerx] #1682174
10/06/14 01:06 PM
10/06/14 01:06 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Are the Aerospace brakes that everyone is using a vented rotor, or non vented like the strange drag brakes?
Re: Aerospace brakes Good, Bad, Junk? [Re: mshred] #1682175
10/06/14 02:07 PM
10/06/14 02:07 PM
Locomotion Offline
Locomotion  Offline
I have a set of their vented rotors but haven't gotten around to installing them yet. The thicker, vented rotors still weigh less than OEM, but will provide some extra durability if I get into a "hot lap" situation. I got Aerospace Components because I heard good things about them as well.
Re: Aerospace brakes Good, Bad, Junk? [Re: DemonDust] #1682176
10/06/14 02:25 PM
10/06/14 02:25 PM
louisiana,usa
O
olemopar Offline
olemopar  Offline
O
louisiana,usa
Both front and rear bought used of a member here no issues works great
Re: Aerospace brakes Good, Bad, Junk? [Re: Locomotion] #1682177
10/06/14 03:34 PM
10/06/14 03:34 PM
Toronto
mshred Offline
mshred  Offline
Toronto
What is the weight savings of the vented rotors vs. stock components? I would be installing these on a street/strip car and would need rotors that can stand the constant stopping of this type of driving.
It is good to read that the aerospace brakes are working well for most, as I could swear I read on here awhile ago digging through old threads that the aerospace brakes need to "pump up" before you get a positive pedal feel- something iirc people were complaining about when going to jump on the brakes at the big end
Re: Aerospace brakes Good, Bad, Junk? [Re: mshred] #1682178
10/06/14 05:25 PM
10/06/14 05:25 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I had them front and rear on my Duster, and that's how mine were. I had to give the pedal a quick partial pump, and then push the pedal again for full stopping power. I bled the brakes many times, thinking it was air somewhere in the lines. IIRC, the pistons inside the calipers retract a little bit, to eliminate any chance of brake drag going down the track.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Aerospace brakes Good, Bad, Junk? [Re: DusterDave] #1682179
10/06/14 05:34 PM
10/06/14 05:34 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Yes, and if I recall more than one person was experiencing the same or similar things....Those who have responded above, does anybody notice this with their brakes??
Re: Aerospace brakes Good, Bad, Junk? [Re: DusterDave] #1682180
10/06/14 05:34 PM
10/06/14 05:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Mine were the same way..... Little petal "prep" then ready to rock. I replaced stock 340 Duster Kelsey Hayes disk setup. Those, the tire would go about 1/3 of a turn spinning the tire before stopping.
Replaced with the Aerospace units, and tire would spin forever before stopping
1.41 best 60 foot
6.56 at 104.17
Re: Aerospace brakes Good, Bad, Junk? [Re: B3422W5] #1682181
10/06/14 07:15 PM
10/06/14 07:15 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
Aerospace front and rear on my Cuda. I do have the pedal pump up problem on mine. Bled brakes many times with no luck, then installed a Moroso 2psi residual pressure valve hoping to solve the problem. http://www.summitracing.com/parts/wil-260-1874/overview/
It is much better but still not cured. The car stops fine, but it is a PIA to get enough pressure for line lock to hold. I am running the master cylinder they recommended and sold me.
A friend suggested that I may have the small bore master cylinder and that could be the problem. It is one of my things to look at this winter when I do my updates.
Again, it stops fine, but pumping up for line lock is a PIA.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Aerospace brakes Good, Bad, Junk? [Re: GTSDave] #1682182
10/06/14 07:30 PM
10/06/14 07:30 PM
Kissimmee Fl.
Kissimmee Fl.
-Dave
A big thing with the Aerospace is having the correct pedal ratio.
Mine did retract the pistons a small amount that's the way they are made to reduce drag.
Once I corrected the pedal ratio I had 0 problems setting the line lock and the car would stop just fine with no pedal pump, but the pedal did feel a little nicer if you just gave it a quick pump.
Re: Aerospace brakes Good, Bad, Junk? [Re: dusturbd340W5] #1682183
10/06/14 08:14 PM
10/06/14 08:14 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
We have them on the front and rear. Had some issues with the front/rear bias and the technical support was outstanding. They provided system pressures on the front/rear so we could sort that out. I sent all the calipers back to them to be rebuilt last year since we didn't know the history on them and the fee was reasonable. We are running the MP master cylinder with no issues.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
