Re: Aerospace brakes Good, Bad, Junk?
[Re: DemonDust]
#1682165
10/05/14 12:35 PM
10/05/14 12:35 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Jesse That what I have on my Duster front and rear and very happy with them.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 440W8 Duster]
#1682166
10/05/14 01:51 PM
10/05/14 01:51 PM
Posts: 437 south central pa
bdaz smblk
south central pa
I have them on the front and rear of my dart and love them.My brother runs them on his dart and really likes them to.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
[Re: bdaz smblk]
#1682167
10/05/14 02:23 PM
10/05/14 02:23 PM
Posts: 11,728 Portage,michigan
B3422W5
Portage,michigan
As I said in the other thread, ran the front for years and never an issue, new owner of car still has same set on, some 10 years now after I put them on.
[Re: B3422W5]
#1682168
10/05/14 02:29 PM
10/05/14 02:29 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
No offense to you Don at all. I just wanted to make sure I was going the right way after I heard someone say several race shops said they were no good. I figured a thread with this brand specific would bring out anyone with hostility toward them and get more of an explanation than "race shops said so".
[Re: DemonDust]
#1682170
10/05/14 02:44 PM
10/05/14 02:44 PM
Posts: 145 NJ
cb1289
NJ
We have Aerospace on 3 cars. 3800lb Supra, all 4 wheels, mid 9sec,145mph, street & strip,4yrs. 2800lb Pickup, fronts only, high 8sec,150mph, strip only,2yrs. 3700lb Dodge wagon, fronts only, mid 10sec, strip only, just installed this season. No issues,easy install.
62 Dodge Dart Wagon
65 Plymouth Satellite
[Re: cb1289]
#1682171
10/05/14 02:56 PM
10/05/14 02:56 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I had there front and rears on my car along with the master cylinder that they had in stock and they where great never an issue at all.
And I got great customer service as well, a year after my purchase I made some changes to the rear end and needed some more shims I made 1 call to them and they shipped me some shims that day at no charge.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1682172
10/05/14 04:36 PM
10/05/14 04:36 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Have fronts on my car and are happy with them
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Locomotion]
#1682177
10/06/14 03:34 PM
10/06/14 03:34 PM
Posts: 3,425 Toronto
mshred
Toronto
I have a set of their vented rotors but haven't gotten around to installing them yet. The thicker, vented rotors still weigh less than OEM, but will provide some extra durability if I get into a "hot lap" situation. I got Aerospace Components because I heard good things about them as well.
What is the weight savings of the vented rotors vs. stock components? I would be installing these on a street/strip car and would need rotors that can stand the constant stopping of this type of driving.
It is good to read that the aerospace brakes are working well for most, as I could swear I read on here awhile ago digging through old threads that the aerospace brakes need to "pump up" before you get a positive pedal feel- something iirc people were complaining about when going to jump on the brakes at the big end
[Re: mshred]
#1682178
10/06/14 05:25 PM
10/06/14 05:25 PM
Posts: 1,845 Tampa
DusterDave
Tampa
I had them front and rear on my Duster, and that's how mine were. I had to give the pedal a quick partial pump, and then push the pedal again for full stopping power. I bled the brakes many times, thinking it was air somewhere in the lines. IIRC, the pistons inside the calipers retract a little bit, to eliminate any chance of brake drag going down the track.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1682179
10/06/14 05:34 PM
10/06/14 05:34 PM
mshred
Toronto
Yes, and if I recall more than one person was experiencing the same or similar things....Those who have responded above, does anybody notice this with their brakes??
[Re: DusterDave]
#1682180
10/06/14 05:34 PM
10/06/14 05:34 PM
B3422W5
Portage,michigan
Mine were the same way..... Little petal "prep" then ready to rock. I replaced stock 340 Duster Kelsey Hayes disk setup. Those, the tire would go about 1/3 of a turn spinning the tire before stopping. Replaced with the Aerospace units, and tire would spin forever before stopping
[Re: B3422W5]
#1682181
10/06/14 07:15 PM
10/06/14 07:15 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Aerospace front and rear on my Cuda. I do have the pedal pump up problem on mine. Bled brakes many times with no luck, then installed a Moroso 2psi residual pressure valve hoping to solve the problem. http://www.summitracing.com/parts/wil-260-1874/overview/It is much better but still not cured. The car stops fine, but it is a PIA to get enough pressure for line lock to hold. I am running the master cylinder they recommended and sold me. A friend suggested that I may have the small bore master cylinder and that could be the problem. It is one of my things to look at this winter when I do my updates. Again, it stops fine, but pumping up for line lock is a PIA. -Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: dusturbd340W5]
#1682183
10/06/14 08:14 PM
10/06/14 08:14 PM
Posts: 1,443 Maryland
Dads426
Maryland
We have them on the front and rear. Had some issues with the front/rear bias and the technical support was outstanding. They provided system pressures on the front/rear so we could sort that out. I sent all the calipers back to them to be rebuilt last year since we didn't know the history on them and the fee was reasonable. We are running the MP master cylinder with no issues.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
