Re: Aerospace brakes Good, Bad, Junk?
[Re: mshred]
#1682184
10/06/14 11:05 PM
10/06/14 11:05 PM
Posts: 5,894 Florida
Locomotion
What is the weight savings of the vented rotors vs. stock components? I would be installing these on a street/strip car and would need rotors that can stand the constant stopping of this type of driving.
Sorry, but I hadn't gotten around to actually weighing all of the components. But somewhere I read/heard that is was a little less. Yes, for a dual purpose car, it would be a good idea for the bigger, vented rotors.
[Re: Locomotion]
#1682185
10/06/14 11:11 PM
10/06/14 11:11 PM
Posts: 3,421 Toronto
mshred
Toronto
Np, just thought I would ask
I wanted to do light weight brakes over this winter, not sure I am ready to pull the trigger though yet...Strange I find too risky for street driving, Aerospace I read about this "pump up" problem or characteristic if you will, and wilwood I hear are quite heavy...More digging is in order for me..
Sorry if I put this thread somewhat off track...
[Re: dusturbd340W5]
#1682187
10/07/14 01:27 AM
10/07/14 01:27 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
A big thing with the Aerospace is having the correct pedal ratio. Mine did retract the pistons a small amount that's the way they are made to reduce drag.
Once I corrected the pedal ratio I had 0 problems setting the line lock and the car would stop just fine with no pedal pump, but the pedal did feel a little nicer if you just gave it a quick pump.
What did you do to change/correct the pedal ratio. My pedals and rod are the stock 68 Barracuda 4-Speed stuff. It was originally equipped with the manual discs.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
