Need help... removing door/qtr glass in a '71 B-body? #1682067
10/05/14 01:58 AM
10/05/14 01:58 AM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
Hey guys,
I've got a rust bucket '71 Charger I'm scrapping. Today I was trying to remove the door glass and regulators before tossing the doors... but it turned into an exercise in frustration.
I checked my '71 Chrysler/Plymouth/Imperial phone book of a service manual and didn't find it all that helpful.
It appears that I have to remove the 4 fasteners that hold the glass to the lifting track to pull it out. All 4 (3 screws and a bolt) just spin and there doesn't seem to be any way to hold them steady.
It also appears to be impossible to remove the glass without removing this track first. I'd tried to loosen the two vertical glass tracks and pull it all out... I don't think that will work either.
While I'm talking about the two vertical tracks... what the heck were they thinking when they put those two studs on the bottom of the door shell ? Of course they are rusty and square top inside the door is just spinning... and all but impossible to grab with pliers to hold.
I haven't even attempted to remove the qtr. windows yet... but any help would be appreciated.
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Need help... removing door/qtr glass in a '71 B-body? [Re: Slant6pak] #1682068
10/05/14 05:30 AM
10/05/14 05:30 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
If it is a rust bucket you'll probably never get the fasteners out. Try drill them out or pull the glass with the regulars together. I've done that way and is a pain but can be done.
Quarter glass is not as bad as the door glass.
The people that designed these car could have cared less about them 5 to 40 years down the road.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Need help... removing door/qtr glass in a '71 B-body? [Re: moparmarks] #1682069
10/05/14 01:27 PM
10/05/14 01:27 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i've gotten every single one i ever had apart.
some you really have to earn..
soak in pb for hours,even a little heat from a propane torch.
whatever it takes..
Re: Need help... removing door/qtr glass in a '71 B-body? [Re: moparmarks] #1682070
10/06/14 12:42 PM
10/06/14 12:42 PM
Houston, Texas
Houston, Texas
I've already pulled the regulators out... as well the inside door lock parts. I've pulled everything from the top of the window channel except the cat whisker... I even removed the up-stops on the glass. The hole seems too small to pull anything else out assembled.
It all been soaking in PB blaster... and I'm wary of using the torch to heat up parts that are touching glass.
Re: Need help... removing door/qtr glass in a '71 B-body? [Re: Slant6pak] #1682071
10/06/14 03:04 PM
10/06/14 03:04 PM
pa.
dan9 Offline
dan9  Offline
pa.
If you really want them out as a last resort you could grind down the edge of the door skin and remove it. That is if you are trying to save the tracks and glass and scrapping the sheet metal.
Re: Need help... removing door/qtr glass in a '71 B-body? [Re: dan9] #1682072
10/08/14 03:35 PM
10/08/14 03:35 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
The cats whisker has to come out. Then it's easy.
Re: Need help... removing door/qtr glass in a '71 B-body? [Re: Slant6pak] #1682073
10/08/14 06:37 PM
10/08/14 06:37 PM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i was wary myself but i had soaked it in pb for a week
and i was just about to give it up.
mind you the glass was already out of the door and on a bench!
you don't go crazy,just warm up the screw a little for a few seconds.
i was amazed at what a liitle heat did,it almost fell apart..
thats all it took..
