Page 2 of 3 1 2 3
Re: fast 60 ft, slow mph HELP [Re: Racebuddy] #1680623
10/06/14 01:17 PM
10/06/14 01:17 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
ET shows the performance of the chassis/suspension....MPH shows the engine's horsepower. Appears to me, looking at the 60' times, that your suspension/chassis is working GREAT. I agree with you, that it should MPH alittle faster. I would suspect a lean condition at top-end of run. I would kill for your 60' times!! I'll trade you my MPH(104-105) for your 60'.
If you like drag racing, support your local track.
Re: fast 60 ft, slow mph HELP [Re: Cab_Burge] #1680624
10/06/14 01:20 PM
10/06/14 01:20 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
So much for the "8.75 rears won't survive in B-Body race-cars" argument.....
Since I have an A-body guess I`m good 4 ever then............
Re: fast 60 ft, slow mph HELP [Re: Thumperdart] #1680625
10/06/14 02:01 PM
10/06/14 02:01 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Have you cut the engine and done a plug check before driving back to the pits to check it's not lean or pig rich.I usually take a spare plug and a small wrench, swap it over and check it in the pits. I also had a problem with my motor laying over and it was the carb too close to the scoop. I ran without the hood and it was back where it normally is.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: fast 60 ft, slow mph HELP [Re: Racebuddy] #1680626
10/06/14 02:37 PM
10/06/14 02:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I ASSume no wideband to peek at at wfo to see if the afr`s are good or not............
Re: fast 60 ft, slow mph HELP [Re: Thumperdart] #1680627
10/07/14 01:44 PM
10/07/14 01:44 PM
Muncie
Racebuddy Offline OP
Muncie
Correct, no wideband gauge yet.
Plugs are impossible to read. I check for the blue heating of the plug. Its at 88 jet front with PV and 94 rear. the hard starting is the telltale symptom here I believe.
But that could something to look at. It is kinda slow all the way down the track.
I have run this same specs of a motor before on race gas and more compression and it was ungodly powerful and fast in my Sapporo.
that gear drive has my mind boggled some. I guess I could put a new chain on it and test it out with straight up or retarded settings
Re: fast 60 ft, slow mph HELP [Re: Racebuddy] #1680628
10/07/14 05:08 PM
10/07/14 05:08 PM
sweden
sshemi Offline
sshemi  Offline
sweden
My holley black is not enough on my car.
About 520 hp 408 4 speed 3.73 3780 lbs.
It quits at about 5700 rpms in forth.
Stock type pick up but 1/2" to 1/2" alu line to filter then an8 to reg then two an6.
Re: fast 60 ft, slow mph HELP [Re: sshemi] #1680629
10/07/14 05:22 PM
10/07/14 05:22 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I went 10.24 at 130 mph in my car with a holley blue, 3/8 line and the small holley reg.
Great 60 ft though, best i've ever gone is 1.39.
Mick
best 60ft 1.36
Re: fast 60 ft, slow mph HELP [Re: sshemi] #1680630
10/07/14 05:48 PM
10/07/14 05:48 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I suspect your issue isn't the fuel pump.
I ran a Holley black on my 422 small block for years( 650 ish horse) 9.80's at 3350 pounds at 7300-7500 every pass.
Swapped to a much bigger system and saw nothing, zero difference.
At 520 horse a blue should even likely be adequate.
Could be filter, pickup, voltage, regulator...... But that pump should be plenty adequate
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: fast 60 ft, slow mph HELP [Re: sshemi] #1680631
10/07/14 05:56 PM
10/07/14 05:56 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
How do you get a sb A body to 3780 # ?
best 60ft 1.36
Re: fast 60 ft, slow mph HELP [Re: deaks] #1680632
10/07/14 07:56 PM
10/07/14 07:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
OK, now armed with more info I'll take my 2nd stab at this issue. I don't see that it was mentioned that the cam was degreed. Killer 60 ft. It kicks back while cranking. Doesn't pull down on the gear change. Smells of high cylinder pressure and big torque. How much cylinder pressure does it have? Leads me question if the cam isn't advanced further than desired?
Doug
Re: fast 60 ft, slow mph HELP [Re: B3422W5] #1680633
10/08/14 03:03 AM
10/08/14 03:03 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Forgot to mention i run E85.
Filter is on of those inline tubes with a mesh in.
Shouldnt restrict much?
From filter i have a an8 hose to the regulator witch is the cheap holley modell.
After reg i have jegs prebent steel tubing kit.
Cant really see the restriction exept maybe regulator.
Re: fast 60 ft, slow mph HELP [Re: deaks] #1680634
10/08/14 03:06 AM
10/08/14 03:06 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Oh boy here we go again....
It can be done! Im 220lbs. Lots of sound deadener, only lightweight parts are radiator and mastercylinder.
Re: fast 60 ft, slow mph HELP [Re: sshemi] #1680635
10/08/14 03:18 AM
10/08/14 03:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I would agree with others as the Holley black pump should be more then enough for your setup. I use the Holley black pump also and have the regulator press set at 6 psi. I use 3/8 line and a stock fuel tank with a stock 3/8 sending unit. It feeds my car fine as I have no fuel starve problems at all. I actually had the red pump on before and switched to the black just to be sure it was getting enough fuel but it ran the same 10.70's with the Holley red pump also. Ron
Re: fast 60 ft, slow mph HELP [Re: 383man] #1680636
10/08/14 04:53 AM
10/08/14 04:53 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I agree but obviously its not doing good.
It should be enough thats why i use it.
Maybe i should do a flow test?
Also remember that it starts to give up at about 130 mph in a very heavy car.
If i run 1/8 it works fine.
Re: fast 60 ft, slow mph HELP [Re: sshemi] #1680637
10/08/14 06:55 AM
10/08/14 06:55 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
When i upgraded my fuel system, the car did pick up.
Just curious sshemi.
best 60ft 1.36
Re: fast 60 ft, slow mph HELP [Re: sshemi] #1680638
10/08/14 10:11 AM
10/08/14 10:11 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If you have a 3700 pound car going 130 mph+...... You are making way more steam than 520 horse
1.41 best 60 foot
6.56 at 104.17
Re: fast 60 ft, slow mph HELP [Re: B3422W5] #1680639
10/08/14 10:48 AM
10/08/14 10:48 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
According to Wallace.
523 = 120mph
665 = 130mph
best 60ft 1.36
Re: fast 60 ft, slow mph HELP [Re: 383man] #1680640
10/08/14 11:18 AM
10/08/14 11:18 AM
Muncie
Muncie
the Holley black pump is for the dedicated NOS line. The engine runs on a big ole Aeroquip pump with a 8 AN line.
Re: fast 60 ft, slow mph HELP [Re: Racebuddy] #1680641
10/08/14 11:23 AM
10/08/14 11:23 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Sorry about the misunderstanding...
Could it be the transmission?
Ive seen that before.
Re: fast 60 ft, slow mph HELP [Re: deaks] #1680642
10/08/14 11:23 AM
10/08/14 11:23 AM
Muncie
Muncie
2 new batteries, digital 6 ignition, crank trigger, petronix coil. and an altenator. voltage gauge looks good there
Page 2 of 3 1 2 3
