Mechanicall VS dynamic compressio ratio and fuel ? #1680531
10/01/14 01:06 AM
10/01/14 01:06 AM
Cab_Burge Offline OP
I'm putting together a 440 block 505 C.I. bracket motor(4.350 bore x 4.300 stroke) that has a mecahical compression ratio of 12.60 with a dynamic compression ratio fo 9.08 to 1 according to United Machines on line calculator. The customer wants to mix 110 octane race gas with non ethanol pump gas that has 92 octane here in OR, my question is what percentage would be better for this motor, 50/50 (2.5 gallons of each) or 3 gallons race gas to 2 gallons pump gas for a 66.6 percent of race gas to pump gas I've never heard or paid any attention to dynamic compression ratio before coming onto this site many years ago This is a bracket car only, not street
raced The solid roller cam is 108 LSA in at 106 on the intake and it has 269 @ .050 on the intake and 276@ .050 on the exhaust side, ported 440-1 with no flow numbers, single 1050 dominator on a 440-2 intake modded to fit the dominator carb. pattern.
I am planning on dyno testing it next week on the local Studka dyno that has been calibrated recently, I'll ask to have it recalibarted for this motor, it has had a bunch of SB Chevys on it and may have been tweaked for those tests Just kidding on the tweaking
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Cab_Burge] #1680532
10/01/14 04:04 AM
10/01/14 04:04 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i run 93 on my 11.25 Mechanical CR, SB. It does have about 200 cranking psi.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Cab_Burge] #1680533
10/01/14 09:34 AM
10/01/14 09:34 AM
gregsdart Offline
gregsdart  Offline
The fuel octane will be in direct proportion to the mix.(Edit; I stand corrected, non leaded only) No expert hear, but would think 50/50 should work. It would be nice to have a knock sensor on that dyno, just in case there was a hint of trouble. It would be good to have the extra octane in the tank though. Like for when my electric pump quit in the staging lanes just before the burnout! I didn't see it till the return road.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Cab_Burge] #1680534
10/01/14 10:45 AM
10/01/14 10:45 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Personally I think it needs straight 110 leaded to be bracket raced on. Maybe can get away with mixing it on the street, but racing it's gonna need all that 110 can provide at near 13-1. I've been selling race fuel for 25 years.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Cab_Burge] #1680535
10/01/14 10:59 AM
10/01/14 10:59 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've never played with the dynamic pressure to octane
to see what will work and be safe... plus different
fuels will knock at different rates so start on the
safe side... but I always try to reduce octane a little
at a time... I see the engine running better and quicker
with a lesser octane thats ends up being correct..
I wish there was a quick chart to use for a relation
of dynamic to octane(and be close)... when I was
talking with Dan on my SB he gave me a number for
the dynamic that I should stay under for pump gas
but I would have to find it
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Cab_Burge] #1680536
10/01/14 11:20 AM
10/01/14 11:20 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Will the dyno graph show detonation? A local racer told me a while back that he could identify detonation on the dyno by comparing the graphs. He said detonation makes the line much choppier. Any truth to that?
And have you thought about water/meth injection? It would be a lot less trouble than mixing and may save some money in the long run with the cost of race gas today.
Master, again and still
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Cab_Burge] #1680537
10/01/14 03:43 PM
10/01/14 03:43 PM
dogdays Offline
dogdays  Offline
The 110 race gas is rated by the Research method.
The 92 pump gas is rated by the (R+M) / 2 method. Rated by the Research method it'd be around 97 RON.
If the 110 has tetraethyl lead in it, adding the unleaded to it will not change the octane rating in direct proportion to the mix, because TEL follows the law of diminishing returns. So, the first gram changes the octane more than the second gram, which is more than the third gram, etc. This means that the last gram in the race gas turns into the first gram in the unleaded and the result is higher octane than you would expect, although lower than 110.
If the 110 is unleaded, then the octane changes in direct proportion to the mix. So 50/50 would get 97/2 + 110/2 = 103.5 RON.
R.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: dogdays] #1680538
10/01/14 03:57 PM
10/01/14 03:57 PM
Cincinnati, Ohio
Cincinnati, Ohio
R.
I believe 104 is as high as you can go without lead. And 104 is full of ethanol, way more than 10% to get it to 104. So I'm sure 110 is leaded.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Challenger 1] #1680539
10/01/14 04:33 PM
10/01/14 04:33 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
You can buy 110 unleaded all over town here in Detroit.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Blusmbl] #1680540
10/01/14 04:43 PM
10/01/14 04:43 PM
Cincinnati, Ohio
Cincinnati, Ohio
I said I believe.
I think you should look closer, Here's Sunoco's list of unleaded fuels which I have been selling for years. Does not mean someone else is not selling 110 unleaded but I have never seen it. Show me some proof.
Here's sunoco list.
web page
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: MR_P_BODY] #1680541
10/01/14 05:07 PM
10/01/14 05:07 PM
Kirkland, Washington
Pacnorthcuda Offline
I hear to stay under 8.5 dynamic for pump gas (92 here). On my motor thats 10.2 static--I was going to shave the AL heads to 10.5 but decided I better not.
My Voodoo cam intake closes at 60, thats pretty early, not too forgiving to high compression ratios.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Blusmbl] #1680542
10/01/14 06:37 PM
10/01/14 06:37 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Same here, says right on the pump "unleaded".
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: justinp61] #1680543
10/01/14 06:47 PM
10/01/14 06:47 PM
Cincinnati, Ohio
Cincinnati, Ohio
What does a gallon of 110 unleaded cost?
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: justinp61] #1680544
10/01/14 06:49 PM
10/01/14 06:49 PM
Az
Crizila Offline
Crizila  Offline
Az
Trust me, Sunoco 110 is leaded fuel. Don't are what the pump sez. Look on their web sight.
Fastest 300
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Crizila] #1680545
10/01/14 06:54 PM
10/01/14 06:54 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't see Sunoco mentioned in my post or the one I quoted. There are no Sunoco stations here.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: MR_P_BODY] #1680546
10/01/14 06:55 PM
10/01/14 06:55 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mike if you find the number Dan gave you can you post it?
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Challenger 1] #1680547
10/01/14 06:57 PM
10/01/14 06:57 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
The last time I bought any was six or so years ago and it was $6 a gallon then.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: justinp61] #1680548
10/01/14 06:58 PM
10/01/14 06:58 PM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: Cab_Burge] #1680549
10/01/14 07:06 PM
10/01/14 07:06 PM
AndyF Offline
AndyF  Offline
For bracket racing the guy will want to run straight VP-110. If it was my motor I'd probably run C-12 but VP-110 should work.
Dynamic compression doesn't mean anything on a race engine. Once the engine is up on the cam you'll have 100% compression if not more due to the ram tuning.
You can get away with pump swill if you're just idling around town, once you get that engine under full load you'll need good gas.
Re: Mechanicall VS dynamic compressio ratio and fuel ? [Re: justinp61] #1680550
10/02/14 01:34 AM
10/02/14 01:34 AM
Az
Crizila Offline
Crizila  Offline
Az
Ok. So, what 110 unleaded fuel is available all over Detroit?
Fastest 300
