Remanufacturd Engines #1677279
09/26/14 04:06 PM
09/26/14 04:06 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
What's up, all. In ya'lls opinion, who does the best quality remanufactured short/long block engines? Any stories/personal experiences would be welcome. Thanks for any help!
Re: Remanufacturd Engines [Re: 440child] #1677280
09/26/14 04:15 PM
09/26/14 04:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Depends on what you want to use the engine for.
Re: Remanufactured Engines [Re: stumpy] #1677281
09/26/14 05:05 PM
09/26/14 05:05 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
Just to put into a work truck, to use as a daily driver if need be, nothing performance oriented.
Re: Remanufactured Engines [Re: 440child] #1677282
09/26/14 05:17 PM
09/26/14 05:17 PM
Georgia
K
KingTuna Offline
KingTuna  Offline
K
Georgia
I've heard good things about Carolina engines. Google them and check it out.
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: Remanufacturd Engines [Re: 440child] #1677283
09/26/14 06:03 PM
09/26/14 06:03 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've installed 3 Jasper engines and they all have been good.
GM makes some good ones too, if this is GM?
Re: Remanufacturd Engines [Re: Challenger 1] #1677284
09/26/14 07:48 PM
09/26/14 07:48 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I agree with the GM stuff....the Jasper stuff???....not so much. Was years ago but I did a Cadillac 3 times and a Chev BB twice. The shop I was at quit using them.
Re: Remanufacturd Engines [Re: Challenger 1] #1677285
09/26/14 09:16 PM
09/26/14 09:16 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
It's an '85 Dodge pickup. I thank everyone for the replies & suggestions so far. I'm interested in this route 'cause I can switch over things in a weekend (or so)& have some type of warranty.
Re: Remanufacturd Engines [Re: 440child] #1677286
09/26/14 10:26 PM
09/26/14 10:26 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I've installed several Jasper engines over the years and all were fine.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Remanufacturd Engines [Re: HemiRick] #1677287
09/29/14 11:08 AM
09/29/14 11:08 AM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
The few remans I did ( just basic engines, no HIPO) all had cranks that were 30/30 or 40/40.. Engines worked great but we used to throw away cranks ground that much....
Re: Remanufacturd Engines [Re: floridian] #1677288
09/29/14 11:58 AM
09/29/14 11:58 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
I supply many engine rebuilders crank and cam grinding products around the country and have for 20 years. There is the good the bad and the ugly. Many sub par big engine rebuilders PER's Production Engine Rebuilders have closed up and that has allowed the good ones to only get better. Jasper Engines engines has 2 plants 1 in Jasper and 1 in Leavenworth, Indiana both are excellent and well ran operations, AER Automotive Engine Rebuilders has 2 plants in Carrolton, Tx (Dallas) They are an authorized Ford reman. These 2 are tops in the country in my book. These 2 builders are the best in my opinion. There are few others but in my opinion these are the 2 I would buy from. I have made 100's of visits to shops and companies nation wide and have seen it ALL.
MLR426
Re: Remanufacturd Engines [Re: MLR426] #1677289
09/29/14 03:30 PM
09/29/14 03:30 PM
Martinsville, VA
440child Offline OP
440child  Offline OP
Martinsville, VA
Thank you guys! This is great information!
