383/400 low profile intake options #1676783
09/25/14 01:53 PM
09/25/14 01:53 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Hi all - I know there have been tests done, but I'm looking for a low profile intake to bolt onto a 400 engine with stock heads (some porting). I don't want to mess with the kickdown or throttle cable linkage, and not looking to make max power, just make a quick bolt on swap from the factory boat anchor. Any upgrade from stock would be nice. I know the performer intake is out there, and if I recall, there is not much gain over stock other then the weight loss.
The engine also sports a Crane powermax hydraulic ft cam 224/234 @.050, .467/.494 lift, 114 lsa, 750 edelbrock carb and headers, in a 71 D200 truck.
Any info is appreciated. thanks!
2 kids and a dog
Re: 383/400 low profile intake options [Re: TonyS451] #1676784
09/25/14 02:12 PM
09/25/14 02:12 PM
dogdays Offline
dogdays  Offline
Why low profile? I didn't know there was a clearance problem on the Sweptlines.
Torker 383 would match the engine, although the Edelbrock Perf RPM would do better on the street.
Actually on that truck a tunnel ram with 2-4s sticking through the hood would be cool.
R.
Re: 383/400 low profile intake options [Re: TonyS451] #1676785
09/25/14 02:36 PM
09/25/14 02:36 PM
Earth
Rob C Offline
Rob C  Offline
Earth
So, to answer your question to help you out....
The Holley Street Dominator is the lowest sitting intake I can think of. Works well with otherwise stock engines and carb. I using one now on a 400 & a TQ. Mileage is fine as well as throttle response.
Re: 383/400 low profile intake options [Re: TonyS451] #1676786
09/25/14 03:36 PM
09/25/14 03:36 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Its up to you but if it's for the street I would stay dual plane. I put a Torker on mine. It killed all the bottom end. Runs good up in the R's where I usually don't drive though.
...FAFO...
Re: 383/400 low profile intake options [Re: skicker] #1676787
09/25/14 03:42 PM
09/25/14 03:42 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Tony the DP4B edelbrock is a good intake. In the testing a few years ago it was not far behind the rpm and it is low profile and will pass for stock painted and properly massaged.
Getting old just means you were smarter than some and luckier than others.
Re: 383/400 low profile intake options [Re: skicker] #1676788
09/25/14 03:48 PM
09/25/14 03:48 PM
dogdays Offline
dogdays  Offline
Here's the first part of the article.
http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/viewall.html
Edelbrock DP4B seems to be a winner, and it is short. The Torker 383 isn't too much taller, and may work quite well with your cam choice. That's why I suggested it. Also you can get one cheap. I got mine for less than $100, I think it was $50.00.
Here's the second part, switching to better heads....http://www.hotrod.com/techarticles/hrdp_0801_mopar_intake_manifolds/viewall.html
Now you can make your own decision in your own time.
R.
Re: 383/400 low profile intake options [Re: TonyS451] #1676789
09/25/14 05:30 PM
09/25/14 05:30 PM
AndyF Offline
AndyF  Offline
I don't think you have many choices for a new low profile B intake. The Edelbrock Performer might be the only one currently available.
Re: 383/400 low profile intake options [Re: AndyF] #1676790
09/25/14 05:50 PM
09/25/14 05:50 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
The performer is the same as the DP4B only spun 180 degrees , it should give the least issues with the TV linkage.
Re: 383/400 low profile intake options [Re: JohnRR] #1676791
09/25/14 07:17 PM
09/25/14 07:17 PM
Chicago, IL
TonyS451 Offline OP
TonyS451  Offline OP
Chicago, IL
Thanks everyone for the input. I have spotted a couple 383 SD intake at upwards of 400 bucks, and not much else out there in terms of intakes that would fit my bill. I think the Performer will do just fine for what I need, plus they are easy to come by. Thanks again, guys.
2 kids and a dog
Re: 383/400 low profile intake options [Re: skicker] #1676792
09/25/14 09:41 PM
09/25/14 09:41 PM
SE PA
Yellow Fever Offline
SE PA
Yup, I went from a torker to an Eddy RPM and it made all the difference on my 450 stroker. Although the rpm was taller than the torker.
Re: 383/400 low profile intake options [Re: TonyS451] #1676793
09/25/14 10:59 PM
09/25/14 10:59 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Crazy what they want for used low deck SD intakes ...Holley are you listening? With the onslaught of low deck big cube strokers, there's obviously a market. With that said...the DP4B will fit the bill...I had one on a 470" for a while, worked good. The RPM that replaced it really woke up the midrange though. I sold the DP4B for $150...it sold in an hour the 1st time I tried.
Re: 383/400 low profile intake options [Re: TonyS451] #1676794
09/25/14 11:26 PM
09/25/14 11:26 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
The CH4B or the Performer will fit the bill for your needs perfectly.
Re: 383/400 low profile intake options [Re: BSB67] #1676795
09/25/14 11:41 PM
09/25/14 11:41 PM
USA
hudsonhornet7x Offline
USA
Not to hijack the thread, but does anyone know what the tallest intake would be for a low deck engine in a 68 Charger with a stock hood?
Re: 383/400 low profile intake options [Re: Yellow Fever] #1676796
09/26/14 12:00 AM
09/26/14 12:00 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Tony I had a B eng Holley Street Dominator that was on my sons Dart about 5 years ago. I think a friend still has it as I can find out if you like. I know if I can get it from him it wont even cost half of the $400 as I think I could get it for a fair price. Let me know if you want me to try and get it for you. Ron
Re: 383/400 low profile intake options [Re: BSB67] #1676797
09/26/14 03:49 PM
09/26/14 03:49 PM
dogdays Offline
dogdays  Offline
CH4B is for 440s.
DP4B is for 383s and 400s
R.
Re: 383/400 low profile intake options [Re: hudsonhornet7x] #1676798
09/26/14 06:43 PM
09/26/14 06:43 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
A Perform RPM should fit with a drop base air cleaner. This is what I am using on my 383 and it fit under the stock hood of my 69 Road Runner.
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: 383/400 low profile intake options [Re: Ray440] #1676799
09/26/14 06:45 PM
09/26/14 06:45 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Here is pic with the air cleaner on.
Re: 383/400 low profile intake options [Re: Ray440] #1676800
09/26/14 07:07 PM
09/26/14 07:07 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Does anyone know if the DP4B will work with the stock 1969 Airgrabber setup?
Re: 383/400 low profile intake options [Re: Azzkikrcuda] #1676801
09/26/14 07:24 PM
09/26/14 07:24 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Yes it will, Weiand Action Plus will also work.
Re: 383/400 low profile intake options [Re: Ray440] #1676802
09/26/14 07:28 PM
09/26/14 07:28 PM
USA
USA
Thanks! Looks mighty good there too!
