Engine mounts #1676740
09/25/14 11:08 AM
09/25/14 11:08 AM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
Solid mounts on the street ?
Re: Engine mounts [Re: kotacars] #1676741
09/25/14 09:04 PM
09/25/14 09:04 PM
IN
ahy Offline
ahy  Offline
IN
Not necessary or desirable. With two solid mounts there will be lots of vibration and the engine and chassis will be loading each other up with heating, cooling and flexing.
Solid on the left and regular on the right would be better than two solid. Maybe an OK solution if drag racing but this is the handling section.
I'll suggest best in a handling application is an interlocking or through bolt poly mount on the left and regular poly on the right. The interlocking left mount protects from breakage on heavy acceleration in low gear, at least enough for a handling car. Vibration may be a little worse than OE rubber but not bad. Besides... repop rubber mounts seem to be very low quality now so best to stay away.
Re: Engine mounts [Re: ahy] #1676742
09/26/14 01:00 AM
09/26/14 01:00 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
buy these:
http://chucker54.stores.yahoo.net/newmapopomom.html
or buy the rubber mounts and add a torque strap to the one side of the engine to take the torque
Re: Engine mounts [Re: dangina] #1676743
09/26/14 05:25 AM
09/26/14 05:25 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've ran solid engine mounts on a dailydriver with a solid cammed 440 for a couple of years. But this was on a heavy '67 Newport so the weight of the car absorbed a lot of the vibrations.
Transmount was stock rubber.
Re: Engine mounts [Re: BigBlockMopar] #1676744
09/26/14 05:53 AM
09/26/14 05:53 AM
mass
K
kotacars Offline OP
kotacars  Offline OP
K
mass
This is a 1964 a body I already broke stock rubber mounts even with a torque strap so I machined these
