Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675289
09/22/14 06:28 PM
09/22/14 06:28 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yes it will feed the rocker shafts by just cranking engine, but will take more cranking time to get there than that pressure test port that should show pressure quickly.
Re: no oil getting to rockers on new build? [Re: 80fbody] #1675290
09/22/14 06:36 PM
09/22/14 06:36 PM
Penna
70satelliteguy Offline OP
Penna
"What type & weight of oil are you running & standard or high volume oil pump"
10-30 weight and a Melling HV.
"Yes it will feed the rocker shafts by just cranking engine, but will take more cranking time to get there than that pressure test port that should show pressure quickly.
buildanother : I cranked the motor over for about 10 sec and saw 25 lbs. of oil pressure on my gauge. Was that enough time??
Thank you all for all of the ideas I will try and get back to work on it again soon and report back!
Mike
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675291
09/22/14 09:06 PM
09/22/14 09:06 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Could you actually see the gauge while you were priming?, or was some else watching it for you?
Re: no oil getting to rockers on new build? [Re: BSB67] #1675292
09/22/14 10:19 PM
09/22/14 10:19 PM
Penna
Penna
"Could you actually see the gauge while you were priming?, or was some else watching it for you?"
Can't see gauge but when I stop priming I look as fast as I can in the passenger door to see gauge coming back down. Not sure how much pressure there is but with cranking with starter I have about 25 lbs.
Mike
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675293
09/23/14 11:07 AM
09/23/14 11:07 AM
Penna
Penna
Could a bad oil filter cause low enough pressure that even when cranking the motor I would not see oil at the rockers?
Does the oil go thru the filter before or after the oil pump?
Thanks mIke
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675294
09/23/14 11:12 AM
09/23/14 11:12 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Thanks mIke
No , and No the oil goes thru the pump first.
Take off the rockers shaft and put a wire down the hole to see if the cam bearing is lined up right.
Not sure if it's been mentioned but I remember someone having this issue and it was the cam not being drilled.
Re: no oil getting to rockers on new build? [Re: JohnRR] #1675295
09/23/14 12:55 PM
09/23/14 12:55 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
It seemed like it took a while to get mine primed too. IIRC by running the drill CCW and turning the motor over slowly with a breaker bar was what I found worked. When the motor is spinning over with the starter the cam and oil passages are only open for a short amount of time. When you do get oil with the drill be prepared to clean up the mess as it will put a lot out and run down over the edge of the head.
...FAFO...
Re: no oil getting to rockers on new build? [Re: JohnRR] #1675296
09/23/14 01:13 PM
09/23/14 01:13 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
If you don't get pressure with a HV pump somethings wrong. It should build up in 5-10 sec on the starter with a good battery. 50psi cold on the starter should be no issue. Did you mess with the bypass spring in the pump?
Re: no oil getting to rockers on new build? [Re: skicker] #1675297
09/23/14 01:29 PM
09/23/14 01:29 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Exactly , I just cut the top off a mashed valve cover I have to contain the mess.
Re: no oil getting to rockers on new build? [Re: skicker] #1675298
09/23/14 05:37 PM
09/23/14 05:37 PM
Penna
Penna
"Take off the rockers shaft and put a wire down the hole to see if the cam bearing is lined up right"
Will try this also.
I appreciate all of the reply's. I probably won't get to work on it again for a few day's but will report back what my results are.
Mike
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675299
09/23/14 09:33 PM
09/23/14 09:33 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
Drape a piece of saran wrap over the head.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675300
09/24/14 01:48 AM
09/24/14 01:48 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Will try this also.
Mike
Keep in mind that there are two holes in the cam journal. Find one and try the pump. If nothing happens turn the engine more until the wire finds the other end of the hole. One end of the passage needs to line up with the passage to the head, the other end has to be at 6:00 so that oil can make it into the cam. You're probably fine and I would have started the thing up by now. That said, I did help out a friend recently who had a new roller cam with the hole angles off and they never lined up with the holes in the cam bearing and block simultaneously. It took some die grinder work to chamfer the holes until they did line up. Some expensive pushrods and rockers got burned up before the problem was solved.
Re: no oil getting to rockers on new build? [Re: @#$%&*!] #1675301
09/24/14 12:38 PM
09/24/14 12:38 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
IF you still have 25 lbs of pressure by the time you poke your head in the car I'd say you have pressure !! The issue seems to be that you can't "see" it at the rockers so that would indicate a simple cam oil hole alignment problem.
If you're trying to prime it by hand I'd take a few minutes and set that gauge in the engine compartment where you can see it.
I had a hell of a time getting my motor to prime. It just wouldn't suck oil up. I had the pump on and off at least 3 times because it couldn't possibly be anything else. It finally primed and I can only figure that the pump was too dry.
Re: no oil getting to rockers on new build? [Re: Stanton] #1675302
09/24/14 05:39 PM
09/24/14 05:39 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
I always pack a new pump with Vaseline to help it prime fast.
Ron
Re: no oil getting to rockers on new build? [Re: RJS] #1675303
09/25/14 10:45 AM
09/25/14 10:45 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Ron
Was taught that 35 years ago by a good friend...
...FAFO...
Re: no oil getting to rockers on new build? [Re: 6bblgt] #1675304
09/25/14 02:52 PM
09/25/14 02:52 PM
Penna
Penna
YES !YES! YES!
Thank You All for all of your help!!
I finally got to the car this morning . I took off the rockers and put a wire down each side(Stealth heads must only have one hole to oil the heads in the stands. The other one is blind about an inch down) and could feel it drop into the cam while turning the crank . Low and behold when running the drill and slowly turning the crank I got a GUSHER out of each side!!!
Mike
p.s. You guy's are GREAT!!!!!!!!!!
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675305
09/25/14 05:33 PM
09/25/14 05:33 PM
AndyF Online content
AndyF  Online Content
If you pay attention you should see that the passenger side rocker arms oil when the crank is at TDC overlap. So that is the first place to have the crank when you prime the engine. Then you rotate the crankshaft 450 degrees and the driver side will oil.
Re: no oil getting to rockers on new build? [Re: 70satelliteguy] #1675306
09/25/14 06:05 PM
09/25/14 06:05 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Really ?!?!?! That would mean the heads are not interchangeable side-to-side and you got lucky when you installed them !!!
Actually, the block only has oil passages at the #4 cam journal. The "blockage" you encountered is the deck surface.
