Re: please share your gen 3 Hemi build
[Re: 1badx]
#1674971
10/02/14 01:07 PM
10/02/14 01:07 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Well, that sucks, my car is a damn turd
If I read correctly you said you've only been to the track once and your car went 10.0? What MPH? What was your 60'?
Depending on the compression your getting with those heads and pistons I would think at your weight you should be in the high 9's but if your compression is low enough then maybe not.
I'm not familiar enough with your intake/induction as far as track testing to make a call on that.
I have only been once. I use to be able to go a lot years ago, but I just don't get to go as much anymore.
I was thinking my problems are just the gear in my car.
I would like to hear the motor combo of the 3700 lb car about to go 9s
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#1674974
10/02/14 01:18 PM
10/02/14 01:18 PM
Posts: 412 Portersville, Pa
1badx
Portersville, Pa
430ci, 15:1 compression, Thitek heads, Thitek ported 6.1 intake, 90mm throttle body, PWR designed cam, NAG1 trans, 4000rpm flash converter, 3.06 gear, trans brake, 28" MT ET Streets, custom tuning on our dyno and at the track. Car has run many types of fuel - E85, C16, Q16, C45 - it seems to like the Q16 and C45 the best. The best thing is that this is a 4 door former cop car with a column shift!
OST Dyno - Home of the worlds Quickest and Fastest Supercharged Hellcat! Building and tuning record setting Gen III Hemi’s since 2006!
[Re: 1badx]
#1674975
10/02/14 01:23 PM
10/02/14 01:23 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Ray if my 6.1 makes in the neighborhood of what yours does im gonna be as happy as Ronald fkn McDonald.
Mopar to the bone!!!
[Re: sixpackgut]
#1674978
10/02/14 02:43 PM
10/02/14 02:43 PM
sixpackgut
Charleston
piston on the left was designed by Arrington for boost in 2006 made by JE. the piston on the right are my new ones from Diamond
[Re: 1badx]
#1674985
10/02/14 04:12 PM
10/02/14 04:12 PM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
Just some comments after reading this thread that may be helpful. Not trying to be a "know it all", just sharing what I have experienced.
- The Apache heads will fit on a 5.7 block - Another alternative for good heads is Thitek - The 5.7 block is a cheaper and more readily available alternative. - If using a truck 5.7 block you will need to account for the different dipstick location and if using a pan with a dipstick tube you will need to plug the dipstick tube hole in the truck block. - If using a 5.7 truck block and a 6.1 timing cover and AC you will need to drill and tap 2 holes for the AC bolts in the block. - To delete MDS just replace the lifters. You can leave the MDS components in place - no need for plugs. - These engines do not like a lot of timing so be careful. - Stick with fuel injection and a 6.1 intake for most applications. - NA or forced induction they can make a decent and reliable HP#
We have a 3700# car, NA, 430ci going 10.0 in the heat and should nick 9's shortly.
We also have a 5300# Jeep, turbo, 370ci going high 9's and daily driven.
These engines are impressive and I can't wait to see when someone really starts pushing them!
So what all is involved other than valve clearance pistons when fitting Apaches on a 5.7 block? Bore notch?
[Re: 72Swinger]
#1674988
10/02/14 06:28 PM
10/02/14 06:28 PM
sixpackgut
Charleston
Couple of tech questions
How thick is the 6.1 head gasket
How much lift can the stock springs handle on the 6.4 head?
[Re: sixpackgut]
#1674989
10/02/14 06:56 PM
10/02/14 06:56 PM
72Swinger
Nebraska
I think stock gasket thickness is .036 compressed.
