Page 11 of 16 1 2 9 10 11 12 13 15 16
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675010
10/03/14 01:05 PM
10/03/14 01:05 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I have a 06 5.7 in my colt project. I would like to build around 550-600 hp N/A stroker engine. Could I use the existing heads? Was thinking of getting the Eagle heads.
Re: please share your gen 3 Hemi build [Re: RTSE4ME] #1675011
10/03/14 01:10 PM
10/03/14 01:10 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Cool project and absolutely you can use the existing heads, with some port work.
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1675012
10/03/14 03:01 PM
10/03/14 03:01 PM
Portersville, Pa
1badx Offline
1badx  Offline
Portersville, Pa
Mike at that boost level what valvesprings and lifter setup are you using?
Whatever springs Craig put in the head for my cam specs and the stock 6.1 lifters.
OST Dyno - Home of the worlds Quickest and Fastest Supercharged Hellcat!
Building and tuning record setting Gen III Hemi’s since 2006!
Re: please share your gen 3 Hemi build [Re: 1badx] #1675013
10/03/14 03:36 PM
10/03/14 03:36 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
6.1 SRT Challenger. TTI's into the stock exhaust. 6psi of Procharger boost, 185* thermostat, Diablo Preditor tuner. It runs about 93 MPH in the 1/8 around a 7.70-80 depending on how it hooks. Not bad for 4300# on 20 inch street tires lol
It's filled up a log book with 124 passes since new ,2010-2014!
24000 miles and is a blast to pick my kids up from school
Re: please share your gen 3 Hemi build [Re: FastmOp] #1675014
10/03/14 11:07 PM
10/03/14 11:07 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Great hearing all the different combos
Re: please share your gen 3 Hemi build [Re: 340RICK] #1675015
10/03/14 11:09 PM
10/03/14 11:09 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
1 more
Re: please share your gen 3 Hemi build [Re: 340RICK] #1675016
10/03/14 11:34 PM
10/03/14 11:34 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
I'm beginning to wonder if "pump gas" to you means E85!!!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: please share your gen 3 Hemi build [Re: 340RICK] #1675017
10/04/14 12:06 AM
10/04/14 12:06 AM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Oh my! Rick, they are bad azz. Is that on the shelf or full custom?
Re: please share your gen 3 Hemi build [Re: 1badx] #1675018
10/04/14 04:31 AM
10/04/14 04:31 AM
mexico
dodgestrike Offline
dodgestrike  Offline
mexico
Does anyone have any idea how much boost can the stock 6.4 392 take , power level before the pistons or a rod gives up ? is the block as strong as a 5.7 or is it more like a 6.1 on the sidewalls ? I can pick up one for arround $1,800 from pan to intake , planning on using a 88mm turbo
Re: please share your gen 3 Hemi build [Re: dodgestrike] #1675019
10/04/14 09:57 AM
10/04/14 09:57 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Apparently the 6.4. block is very strong (it's what's in the Hellcat). Stock pistons can't much boost though.
Regardless, if you can get a basically complete 6.4 for $1800 that's about a 1/4 the going rate, BUY IT
Re: please share your gen 3 Hemi build [Re: WO23Coronet] #1675020
10/05/14 12:28 AM
10/05/14 12:28 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I'd love to know exactly what these weigh. No guessing, if you have weighed one, please share.
Mopar to the bone!!!
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675021
10/05/14 11:15 AM
10/05/14 11:15 AM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
What would be the best 5.7 to buy and use in stock form? With possible modifications in the future
I would probably use a carb on it, this would be going in my 71 valiant
Re: please share your gen 3 Hemi build [Re: sixpackgut] #1675022
10/05/14 12:54 PM
10/05/14 12:54 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Custom pistons
They beauty of FAST EFI I have a different tune I made for street crusing on pump 93
Then tune I have raced the car on is using 110
Re: please share your gen 3 Hemi build [Re: 340RICK] #1675023
10/05/14 02:50 PM
10/05/14 02:50 PM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
What are the slim possibilities that someone out there has a 4150 Ritter intake that they want to part with? I was just going to do a 6.1 intake but I think a ritter intake with injectors and a TB elbow on top will look more at place and more bad @!!
Re: please share your gen 3 Hemi build [Re: Charger453] #1675024
10/05/14 07:24 PM
10/05/14 07:24 PM
STEFF Offline
STEFF  Offline
Muscle Motors manufactures the intake Ritter sells. You can get one from them.
Re: please share your gen 3 Hemi build [Re: STEFF] #1675025
10/05/14 07:34 PM
10/05/14 07:34 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Pretty sure it's vice versa. Hughes sells the Ritter intake as well.
Re: please share your gen 3 Hemi build [Re: GTS340] #1675026
10/05/14 07:55 PM
10/05/14 07:55 PM
STEFF Offline
STEFF  Offline
Nope, you are wrong.......Muscle Motors makes it. They borrowed my Drag Pack intake to use as inspiration to create their own.
Re: please share your gen 3 Hemi build [Re: STEFF] #1675027
10/05/14 08:18 PM
10/05/14 08:18 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Nope you are wrong.......Muscle Motors makes it. They borrowed my Drag Pack intake to use as inspiration to create their own.
I guess I received erroneous info
Re: please share your gen 3 Hemi build [Re: GTS340] #1675028
10/05/14 09:11 PM
10/05/14 09:11 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Re: please share your gen 3 Hemi build [Re: 72Swinger] #1675029
10/05/14 10:17 PM
10/05/14 10:17 PM
Bellevue, NE
Bellevue, NE
I know where to order one and plan to pretty soon. I was hoping I'd find someone with an abandoned project or change of direction. Slim chance, but worth a shot. I need all the savings I can get. Got a line on a good, low mileage s500 88mm. It'd make some killer power, but I worry about the lag on 370''.
