Re: please share your gen 3 Hemi build
[Re: 340RICK]
#1674890
09/25/14 01:03 AM
09/25/14 01:03 AM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
6.1 stroker 426ci Manley stroker kit Bullet solid roller .659/.678 262/276 6.1 heads CNC by Modern touched up and valve Job by David Barton 2.10x1.1.60 valve Harland Sharp rockers 3/8 push rods Drag Pak manifold untouched Fast 4150 throttle body Fast XFI/2.0 Made [Email]776HP@7400rpm[/Email] and [Email]610ftlbs@6100rpm[/Email] best of 9.61 at 139mph
Rick, how are you liking the XFI? Also, what are your static and dynamic compression numbers?
[Re: 72Swinger]
#1674892
09/25/14 07:34 PM
09/25/14 07:34 PM
Posts: 3,998 GO BUCKS !!!!!!!
340RICK
GO BUCKS !!!!!!!
I am using stock non MDS lifters that are gutted and had a solid roller grind cam made for it. Also I do have the Harland Sharps that are not cheap Alex The FAST XFI is great now that the motor is happy. I had so many issues with the HYD roller cam and non ADJ rockers valve springs push rods etc... that I had motor issues not EFI tunning issues like I first thought.
[Re: 340RICK]
#1674893
09/25/14 08:06 PM
09/25/14 08:06 PM
AlexP
Houston, Tx
Good to hear, what magic is there in your lifters?
Also, what is the static and dynamic compression?
[Re: 340RICK]
#1674896
09/26/14 01:33 AM
09/26/14 01:33 AM
Posts: 3,433 Toronto
mshred
Toronto
Gutted and fitted with a custom spacer? I guess going solid roller required the use of those Harland Sharp rockers also?
What weight is your car running those times at?...very impressive Rick!
[Re: mshred]
#1674897
09/26/14 02:13 AM
09/26/14 02:13 AM
Posts: 7,131 Amarillo, Texas
BBR
Amarillo, Texas
This is my favorite thread evaaarrrrr.
Drag Week 2011 - 77th place - DD Drag Week 2012 - 2nd place SRBB N/A Drag Week 2014 - Kapooya RMRW 2018 RMRW 2020
[Re: BBR]
#1674898
09/26/14 09:54 AM
09/26/14 09:54 AM
Posts: 625 Indianapolis In. usa
Quickrunner
Soaking all this in like a sponge as I am in the planning and parts gathering stage of my Gen3 build. Keep the info coming! Rick did Barton modify your lifters?
05 Ram 1500 Daytona package 71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
[Re: Quickrunner]
#1674899
09/26/14 11:45 AM
09/26/14 11:45 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Hurry while the blocks are still available!
Mopar to the bone!!!
[Re: 72Swinger]
#1674900
09/26/14 12:02 PM
09/26/14 12:02 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On a 5.7 or a 6.1.. is there certain year blocks that are better than others... as in I'm looking at a 2005 5.7 thats suppose to be a running engine
[Re: MR_P_BODY]
#1674901
09/26/14 01:27 PM
09/26/14 01:27 PM
AlexP
Houston, Tx
No, they're all the same. I'd run a 5.7 block in a really high hp application over a 6.1. Just do a partial fill and run a really good oil cooler.
[Re: MR_P_BODY]
#1674902
09/26/14 01:30 PM
09/26/14 01:30 PM
72Swinger
Nebraska
Any year 6.1 is a win. I have read the early 03-04 5.7 block were thicker walled. An 05 5.7 is as good as any other 5.7 but it also has the benefit of no plug wires and no mds coming from a truck.
[Re: 72Swinger]
#1674903
09/26/14 01:39 PM
09/26/14 01:39 PM
MR_P_BODY
This engine is coming out of a truck so MAYBE I should continue to look... what does it take to kill the MDS... to my understanding the lifters have a slot in them for the solenoid to push something in
[Re: MR_P_BODY]
#1674904
09/26/14 01:42 PM
09/26/14 01:42 PM
AlexP
Houston, Tx
You just need 4 MDS delete plugs from a 6.1 or HD 5.7. If you leave the solenoid in the block but unplugged, it will do weird things. Use the plugs and be done.
[Re: Triple Threat]
#1674906
09/26/14 05:56 PM
09/26/14 05:56 PM
72Swinger
Nebraska
^^^^ that's what I thought I said lol....
