Hemi head oiling #1674318
09/20/14 12:34 AM
09/20/14 12:34 AM
napa ca
P
procharged 484 Offline OP
P
napa ca
With Mopar alluminum heads stage V rocker assembly crower hippo roller lifters with the pushrod oiling should I restrict the oiling through the block . This is a 95 persent street engine.
THANK YOU.
Re: Hemi head oiling [Re: procharged 484] #1674319
09/20/14 09:52 AM
09/20/14 09:52 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
You can but not completely. You still have to lube the shafts.
JAKES AUTOMOTIVE
Re: Hemi head oiling [Re: procharged 484] #1674320
09/20/14 11:39 PM
09/20/14 11:39 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
When I converted to pushrod oiling in my Hemi I restricted the oil to the heads and plugged the unneeded squirt holes in my Landy rockers.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Hemi head oiling [Re: procharged 484] #1674321
09/21/14 01:49 AM
09/21/14 01:49 AM
if your running roller lifters and the appropiate valve springs, above 600 lbs open, I wiouldn't restrict the oil to the rocker arms at all The oil does help cool the valve springs especially at or above 2000 RPM The real concern should be getting the oil back into the pan unrestricted
Re: Hemi head oiling [Re: Cab_Burge] #1674322
09/21/14 10:43 AM
09/21/14 10:43 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Unless your running Jessel or T/D individual shaft rockers why would you want pushrod oiling?We would rather fab some type of priority oiling to the rockers or use spray bars before going the pushrod oiling.If you loose one lifter you can loose all your topend oiling very quickly.Oiling through the shafts give you a volume of reserve oil in the shafts.
