Shaved door handles #1669374
09/09/14 07:27 PM
09/09/14 07:27 PM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Anybody done this? What about a kit like this?
http://www.ebay.com/itm/New-SPAL-Basic-S...484&vxp=mtr
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Shaved door handles [Re: AZ_A12_BEE] #1669375
09/09/14 07:50 PM
09/09/14 07:50 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Came really close to putting a kit in for the sake of locking my truck. But I didn't because of the safety factor and you can't race a car with shaved handles.
If you have stock working door latches leave them be until they break.
Re: Shaved door handles [Re: moparpollack] #1669376
09/09/14 08:06 PM
09/09/14 08:06 PM
Dreaming of the 808
Dreaming of the 808
That's what I'm afraid of, them breaking. They seem pretty flimsy and add 70+ years of age and it's just a matter of time
Re: Shaved door handles [Re: AZ_A12_BEE] #1669377
09/09/14 08:12 PM
09/09/14 08:12 PM
85086
Lil Herman
Lil Herman
85086
Bear claw latches are a pain if you can make the stock stuff last you will be glad you did.
Re: Shaved door handles [Re: AZ_A12_BEE] #1669378
09/09/14 09:23 PM
09/09/14 09:23 PM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Did it on my Duster. Though I don't use it every day, they have been trouble-free for the last 6 years since installed.
The key to dependable poppers are heavy duty solenoids. Some are simply too small - will function initially and then crap out over time - and that's when you'd curse shaved handles. As others have mentioned, consider the application and goals.
Some pics of my install here with stock latches:
http://www.70duster440.com/customization.html#shaveddoorhandles
http://www.70duster440.com/reassembly.html#popperelectronics
http://www.70duster440.com/reassembly.html#poppers
The ones in that ebay ad look like the "smaller" ones I've seen. Mine are 50lb. But SPAL makes really nice quality fans so....
Re: Shaved door handles [Re: 70Duster440] #1669379
09/09/14 09:54 PM
09/09/14 09:54 PM
moparx Offline
moparx  Offline
i thought about shaved handles on my humpback, but instead, i decided on using flush style handles from a 93-95ish caravan. they will fit directly under the body belt line and since they are black plastic and the body will be dark[leaving the original "patina"], they will practically disappear. i am using the latches from an 84 or so k-car. they are similar to a bear claw, but with a bazillion of k's out there, i'm not worried about dependability.
Re: Shaved door handles [Re: moparx] #1669380
09/09/14 10:50 PM
09/09/14 10:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I've also done the newer car handle and latches on several cars & trucks. The new stuff pretty wide for an old, thin 30s door, I have added about 1/4" (you only need it for about 6" space right at the latch) to the inside of the old thin doors to accommodate the newer latches, it was well worth the extra work. I've used K Car stuff, 80s 5th Ave stuff, and my 48 has Dakota stuff in the doors. We are probably going to put Dakota latches in my sons 57 Dodge, because we have a driver door latch issue. With a little thought, you could use your existing handles with modern latches, if your handles are good.(I'll let you know if we go that way, but the car is on hold right now.
As far as that "Kit", 40lbs solenoids are borderline, I've seen kits with 70lbs solenoids, those would be OK, and have at least 1 door that can be opened if the electrical system is down (dead battery). Gene
Re: Shaved door handles [Re: poorboy] #1669381
09/10/14 07:42 PM
09/10/14 07:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I shaved the handles on my 64 300, but left the original locks.
I rebent the linkage so that the lock opened the door latch. I installed spring loaded poppers to pop the door open when the latch released, though for awhile I just pulled it open with the key. If you wanted to be real retentive you could run pull cables from the door latch to under the hood somewhere as a back up.
Don't be the exception.
Re: Shaved door handles [Re: Supercuda] #1669382
10/02/14 06:59 PM
10/02/14 06:59 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
My '57 Chrysler has shaved doors but since I bought it that way I wouldn't know exactly what kind of kit was used.
I do know if you have the choice between a heavier type of solenoid, always go for the heavier version.
Re: Shaved door handles [Re: BigBlockMopar] #1669383
10/12/14 05:24 PM
10/12/14 05:24 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I got trapped in my 51 yesterday afternoon because of my shaved handles....
It has been sitting about 6 months, no trickle charger....
Got in rolled down the power windows, hit the fuel pump switch and it sounded a little off.... Hit the key engine turned over twice then click click click. Drat, dead battery.
Hit the door switch, and just a slight click, not enough to open the door. Drat...... Oh well gonna just climb out the window....except for one thing. The top is chopped 6" and I am a bit "Fluffy"
Oh well, the boy is in the house will just ring him to come help..... Cell phone is in the house!
About 5 minutes later he comes to the shed on his 4 wheeler to see what I am up to. Just in time to see me try and climb out the window! Well, after a few minutes, I managed to get all the way to my belt with me hanging out the window in a back bend I announce I am stuck. My 11 year old freaked and wanted to call 911 LOL. Finally wiggled my way out and managed not to fall on my head.
I WILL NEVER HAVE ANOTHER CAR WITH SHAVED HANDLES!!!!!!! They have been a PIA ever since I got it.
The doors still have the old 1951 latches, which are worn, and with a car that wants to twist some when I go out playing, they are not dependable. Hell the passenger door swung out on the wife one night. Glad I had installed seat belts!
When I break it down for paint again, it is getting door handles re-installed. It is also getting bear claws.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: Shaved door handles [Re: AZ_A12_BEE] #1669384
10/12/14 05:43 PM
10/12/14 05:43 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Put ones on my truck.
No problems but I would put on a manual pull kit as well.
Re: Shaved door handles [Re: GTSDave] #1669385
10/13/14 06:11 AM
10/13/14 06:11 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
And that is exactly why I did not use electrics when I shaved the handles on my 64. BTW, why did you not have inside handles? What I did was reconfigure the lock linkage so that it opened the latch with the key, rather than the handle. It was all mechanical and worked fine with no dead battery blues.
Re: Shaved door handles [Re: GTSDave] #1669386
10/13/14 10:39 PM
10/13/14 10:39 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
whenever I do door solenoids, I always make the inside release manual just in case of a fire or dead battery.
