Testing shift solenoids in a 94, 46 RH trans #1669253
09/09/14 11:01 AM
09/09/14 11:01 AM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
I'm rebuilding a 1994 46RH transmission in a truck I bought, it wouldn't drive when I brought it home so I don't know if these solenoids work at all. Is there a way to test them before I reinstall them? They are the overdrive and t/c lock up solenoids, it doesn't have any others in it.
thanks.
Re: Testing shift solenoids in a 94, 46 RH trans [Re: MrRico] #1669254
09/09/14 11:18 AM
09/09/14 11:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Ohm them out or apply power and ground momemtarily and listen/feel for the "click'. that's about all you can do on the bench.
Re: Testing shift solenoids in a 94, 46 RH trans [Re: J_BODY] #1669255
09/09/14 01:50 PM
09/09/14 01:50 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Any idea as to how many ohms they need to measure out to?
Re: Testing shift solenoids in a 94, 46 RH trans [Re: MrRico] #1669256
09/09/14 02:37 PM
09/09/14 02:37 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I dont remember the ohm spec but ohm all of them as I believe they should all be about the same. If one is way off it may be bad or of course if its an open circuit its a problem. Seems to me 15 to 30 ohms or somewhere in that area was what I used to get. If you plug in the solenoid pack on the car and then unhook the trans relay and trans controller you can ohm from the relay power wire that powers the solenoids to each solenoid at the trans controller plug. Course having the wire diagrahm will help. I have them around here somewhere but would have to dig them up. Ron
Re: Testing shift solenoids in a 94, 46 RH trans [Re: 383man] #1669257
09/09/14 03:39 PM
09/09/14 03:39 PM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Thank you Ron. I stl have them on the table so no need to go tracking diagrams down right now. I just don't want to go all the way back together with it not knowing if they are bad.
Thank you guys very much. I have gotten into Harleys the past 5 years so I haven't been here much at all but I still have my cars and trucks.
Re: Testing shift solenoids in a 94, 46 RH trans [Re: MrRico] #1669258
09/09/14 07:27 PM
09/09/14 07:27 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
An RH has solenoids? I thought that was RE territory.
Kevin
Re: Testing shift solenoids in a 94, 46 RH trans [Re: Twostick] #1669259
09/09/14 08:05 PM
09/09/14 08:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am sorry as I dont know why but I am thinking FWD intrepid. A RWD RH would just have the lock-up and overdrive solenoids. Sorry. Ron
Re: Testing shift solenoids in a 94, 46 RH trans [Re: 383man] #1669260
09/10/14 01:29 AM
09/10/14 01:29 AM
Dowell, IL
MrRico Offline OP
super gas
MrRico  Offline OP
super gas
Dowell, IL
Thats right all it has are lock up and o/d solenoids but you gotta drain and refill to change them because they are on the side of the valve body. if I can test them to make sure they are good/bad I can save time and money not to mention extra mess and damage a bad solenoid might cause on a new trans rebuild.
