Re: Question on bench bleeding master cylinder [Re: David_Trimble] #1668594
11/15/14 08:15 PM
11/15/14 08:15 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
If you have a JY of parts car near, pull the lines off it, trim the lower ends off and use them to bench bleed it.
Sheldon
Re: Question on bench bleeding master cylinder [Re: RUNCHARGER] #1668595
11/15/14 10:32 PM
11/15/14 10:32 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
teflon tape it...
Re: Question on bench bleeding master cylinder [Re: David_Trimble] #1668596
11/16/14 12:28 AM
11/16/14 12:28 AM
NY NY
3
340duster340 Offline
NY NY
hold your thumb over the hold for the piston out stroke to prevent air from going back in. its ghetto, but it will work in a pinch. repeat as needed, you will need to watch the fluid shooting out to see if there is air in it.
Re: Question on bench bleeding master cylinder [Re: 340duster340] #1668597
11/16/14 01:00 AM
11/16/14 01:00 AM
Have a helper wrap/hold a big towell around/underneath the MC/lines to catch the mess. You work the pedal. EDIT put a brick or block of wood under the pedal so it dont travel past its normal range
Re: Question on bench bleeding master cylinder [Re: RapidRobert] #1668598
11/16/14 08:25 PM
11/16/14 08:25 PM
OK
David_Trimble Offline OP
OK
Re: using JY lines..... what newer model Mopars would I look for that would have compatible lines?
Failing that, that's a good idea using teflon on the back bleed line retainer. I'll also give that a shot, and use the thumb as a check valve.. I'm also watching the back reservoir level to make sure this replacement doesn't have the same issue as the old one - or I'll be back to square 1 again...
Oh and good point about the brick- I had almost forgotten about that.
David
Re: Question on bench bleeding master cylinder [Re: David_Trimble] #1668599
11/17/14 01:15 AM
11/17/14 01:15 AM
NY NY
3
NY NY
you can buy the flare nuts new and bend up your own lines.
also thexton makes a master kit for bench bleeding master cylinders. includes all flare nut sizes metric and standard. here is one i found off amazon, there is another kit that has the carry case and some other stuff.
http://www.amazon.com/Thexton-804-Master...ton+bleeder+kit
either way its a straight forward process once you have the right equipement.
