Re: 75 440 Power Wagon: 4 speed to 727 ideas
[Re: scratchnfotraction]
#1667938
10/12/14 02:24 PM
10/12/14 02:24 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
have you looked into a NV4500 5 speed swap?
Thanks, but I prefer driving an automatic transmission.
[Re: Kern Dog]
#1667939
10/13/14 11:02 AM
10/13/14 11:02 AM
Posts: 15,487 Florida
scratchnfotraction
you are just be lazy with the auto trans. I can see your point though. I was thinking more of the gear ratio split from granny to 2nd you mentioned you did not like granny as it seemd to low and 2nd was a little to high to pull off from a stop all the time...this does make driving one a chore and gets old. But when it is geared just right it is a breeze and better mpg for a 4x4 IMHO. mine was a blast in low range 3rd gear 6200 rpm turning 4.56 gears and 17/40/15 hawgs in the mud pit up to door handles. BUT my auto never would wind up fast enough and did not spit u-joints like the 5 speed did either.they do indeed have their pros and cons.
#1667942
10/14/14 02:10 PM
10/14/14 02:10 PM
Posts: 6,025 Morningside
AdventurerSport
waaaay out there in left field
Morningside
To swap to auto from manual, don't forget to change the radiator (no trans cooler in a manual truck radiator) and run the trans lines to and from the radiatior. You can use an aftermarket floor shifter so that you don't have to swap the steering column for a column shifter, pretty easy.
Keep the NP203, nothing wrong with it and the best Fulltime 4wd case from the '70s, by far (I currently have two of them).
I have an extra BB auto 4wd truck that I'd like to sell, as well, but I'm in IA and probably a little far for you...although it would have all the necessary parts for your swap...
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black 24 Jeep Gladiator Rubicon X 3.6L Pentastar V6, Fulltime 4x4, White
[Re: AdventurerSport]
#1667943
10/14/14 02:35 PM
10/14/14 02:35 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
No need to swap radiator just get a trans cooler. I've swapped in a stick Rad in an auto truck and used an trans cooler. No issues.
Got pics of the truck? I'm just down the road
[Re: Kern Dog]
#1667947
10/15/14 10:17 AM
10/15/14 10:17 AM
scratchnfotraction
I still need to add the yellow stripes to complete the "Macho" look.
SSWWWEEEEETTTT!!!!!!!
I would have some 17/40/15 ground hawgs under that thing bustin sod.
whats the hold up on the yellow stripe?
[Re: 77ProStreet]
#1667949
10/15/14 10:25 PM
10/15/14 10:25 PM
Posts: 10,863 Freeport IL USA
poorboy
Freeport IL USA
Looks outta my price range
Why....cause it's rust free and it runs?
That would be my story, except the I would have to add: Its got shinny paint too.
I have a hard time understanding that "rust free" statement. Around here "rust free" means they are not charging any extra for the rust that is there. "Rust free" and "free rust" pretty much mean the same thing, in my world. Gene
[Re: poorboy]
#1667950
10/15/14 11:45 PM
10/15/14 11:45 PM
Kern Dog
Granite Bay CA
No rust at all on this truck...the oil leaks provided a nice corrosion resistance! Kidding, of course. The yellow stripe kit is being reproduced. I do want to get the kit but I've really spread myself thin with all of the projects here. I don't list my cars or trucks, but along with this 75 PW, I also have a 78 Trail Duster, a 2007 Ram 1500, a 65 Barracuda, a 67 Dart GT, a 71 Duster, 73 Swinger, 74 Duster 360 and this:
[Re: 77ProStreet]
#1667951
10/16/14 04:00 AM
10/16/14 04:00 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Funny.wasn't the truck I was asking about anyway. But in Iowa if it Doesn't have rust it cost more.
[Re: 76dodgeboy]
#1667952
10/16/14 08:30 PM
10/16/14 08:30 PM
AdventurerSport
Morningside
In Iowa, if it doesn't have rust it's A) been restored, or B) it's not from Iowa! JS
