Street Hemi Intake recommendations #1667659
09/04/14 10:33 PM
09/04/14 10:33 PM
North Carolina
469runner Offline OP
North Carolina
I am close to finishing a Hemi for street driving. 472, Stage V heads, fairly mild cam, TTI headers. Trying to come up with a nice intake manifold and carburetor setup to complement this. Was considering the Mopar dual plane 2X4 with the Vanke modification offered by Arruza. Also wondering if the carburetors can use a progressive linkage as stock or a solid linkage? Would a single 4 barrel be something to be considered? Thanks.
Re: Street Hemi Intake recommendations [Re: 469runner] #1667660
09/04/14 10:42 PM
09/04/14 10:42 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Stage V is a much better intake if you don't have to run a stock aircleaner. You really want progressive linkage with a street driven car.
Sheldon
Re: Street Hemi Intake recommendations [Re: RUNCHARGER] #1667661
09/04/14 11:38 PM
09/04/14 11:38 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
I read all the tests on 500+ ci HEMI inline intakes and Stage V came out on top, so I bought one, two 750cfm Hollys, etc. Now, lets get real. #1 What are you doing with the car? Street driving? Maybie a pass down the strip?...someday, maybie? What you need to know is, the factory Carter/Edelbrock, carbs have the fuel line inlet on the PASSENGER side. That leaves lots of room for the linkage, kickdown, etc. on the DRIVER side. They did that for a good reason! It gets VERY crowded when you try to cram all of that on the DRIVER side! Then you have air cleaner issues, now you have to order an air cleaner from ONE sours, in CANADA. It is a Bottom feed, NOTHING like the original It cost over $600 and is "polished" aluminum. I spent $300 ADDITIONAL to chrome it. Do you like the original looking hard lines? I went through TWO 8' LENGTHS of stainless tubing, over $300 for tubing benders, I lost track of the hours I spent trying to "mirror image" the fuel lines. I finally got it, sort of, at least the car show judges haven't noticed, but what a pain! I don't have the "Pentastar" emblem embossed on the intake, I am STILL trying to make a decent return spring bracket that doesn't interfere with the fuel lines, and I absolutely MUST run synchronize carb linkage! The Stage V is an open plenum intake, the REAR carb sees the signal from cylinder #1 etc. It HAS to have both carbs opening TOGETHER! Trust me on this. If I had it to do over, I would buy everything in a kit from Mancini for HALF of what I spent. I have built and tuned HEMIs with the factory intake and Edelbrock 600s and they SCARE me with just 426 ci! and PROGRESSIVE linkage. Oh, buy the way, it all BOLTS ON!
Re: Street Hemi Intake recommendations [Re: 469runner] #1667662
09/04/14 11:50 PM
09/04/14 11:50 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
With a "mild" cam, I think you only have two reasonable options,
the Vanke mod dual plane with two Eddy 650 Thunder Series (AVS) carbs
& progressive linkage.. OR the Stage 5 with two Eddy 650's and non progressive linkage. I had a 540 lift solid flat tappet on my 434
Hemi with the Stage 5 & two Eddy 600's (AFB) & ran great with non progressive linkage. I think the Barton single 4 intake & a big carb
would out perform the Vanke 2x4, but a Hemi always looks better, IMO,
with 2 fours. If you go the vanke route, I"m sure some of the Hemi gurus will chime in with the jetting & spark plug variations that balance them out.
Re: Street Hemi Intake recommendations [Re: Hemi ragtop] #1667663
09/04/14 11:58 PM
09/04/14 11:58 PM
North Carolina
North Carolina
Gotcha. Yes, this will be street driven and needs to fit under an Air Grabber hood. So I would like to use a stock air cleaner. Will the Vanke modification to the dual plane manifold demand that the progressive be eliminated?
Re: Street Hemi Intake recommendations [Re: 469runner] #1667664
09/05/14 12:11 AM
09/05/14 12:11 AM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
I'm using the factory intake eddy carbs and linkage from Mancini. You can buy a steel baseplate to fit the eddy carbs also. This set up works fine on my 528 and still made 645 hp on Barton's dyno. I'm sure I could make more hp with another intake set up but this makes plenty for my street car and everything fits no hassles.
Re: Street Hemi Intake recommendations [Re: HEMIDOG 70] #1667665
09/05/14 12:33 AM
09/05/14 12:33 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Or, you could use a stock intake and try these. Hemi clone carbs, they are based on Edelbrock 600/750/800 cfm carbs, but use reconditioned original lids and reproduction Street Hemi throttle arms so that all factory air cleaners and small parts fit them as exactly as the factory carbs.
If you do the math on buying new unmodified Edelbrocks and associated custom parts to make them work you will likely find the above "clone" option to be very competitively priced and will offer very similar performance on the street.
MANY Pure Stock and FAST racers run these carbs on stock (or internally modified for FAST) Street Hemi intakes and make some HUGE HP numbers!
Re: Street Hemi Intake recommendations [Re: 469runner] #1667666
09/05/14 11:47 AM
09/05/14 11:47 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Single 4 barrel is too easy and wouldn't look right on a hemi. Vanke intake would work, I believe Arruzza likes the solid linkage with it. The hardest way, which would probably run the best, I guess would be the Stage V single plane with the aftermarket lower base and Scott's clone carbs. Nothing's easy.
2011 Drag Pak Challenger
Re: Street Hemi Intake recommendations [Re: HEMIDOG 70] #1667667
09/05/14 12:47 PM
09/05/14 12:47 PM
RUNCHARGER Offline
RUNCHARGER  Offline
I'd like to try AVS' on a Vanke if an Airgrabber is required. Especially if someone makes an Aircleaner for the bigger throats.
The Stage V has wider carb spacing and is I think a quarter inch higher, that's why it's a tough go with a factory airgrabber.
Sheldon
Re: Street Hemi Intake recommendations [Re: RUNCHARGER] #1667668
09/05/14 12:56 PM
09/05/14 12:56 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
Sheldon
Here is a large throat base set up.
http://www.ebay.com/itm/426-Hemi-Air-Cle...=item3394a4a70e
Re: Street Hemi Intake recommendations [Re: HEMIDOG 70] #1667669
09/05/14 02:00 PM
09/05/14 02:00 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I think that guy has the decimal point in the wrong spot. LOL
Re: Street Hemi Intake recommendations [Re: OUTLAWSSAA] #1667670
09/05/14 02:22 PM
09/05/14 02:22 PM
MD-USA
Dodgeguy101 Online content
Dodgeguy101  Online Content
MD-USA
Yeah, he is pretty proud of them.
Re: Street Hemi Intake recommendations [Re: Dodgeguy101] #1667671
09/05/14 02:45 PM
09/05/14 02:45 PM
central P.A.
HEMIDOG 70 Offline
HEMIDOG 70  Offline
central P.A.
They are pricey. I think I paid $300.00 for a swap meet 4bbl fresh air air cleaner set up. Then $300.00 to modify the base for the 2 4bbl's.
Re: Street Hemi Intake recommendations [Re: RUNCHARGER] #1667672
09/05/14 08:58 PM
09/05/14 08:58 PM
Tennessee
Hemi ragtop Offline
Hemi ragtop  Offline
Tennessee
Sheldon
As for the stageV being higher than stock, I don't think so (notice I didn't say I KNEW). All I can say is that I have Zero hood interference, yet a buddy with stock intake and Eddy carbs, had to cut some hood bracing and couldn't clear the factory "Chrome Dome".
What about the "Marine" intake, this would allow larger carbs and I understand that bases are available for any factory style air cleaner?
Re: Street Hemi Intake recommendations [Re: 469runner] #1667673
09/05/14 09:04 PM
09/05/14 09:04 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
How about an old Edelbrock Rat Roaster intake. Works really well on the street and takes the WOW factor way up.
Old Geezer Racing
Re: Street Hemi Intake recommendations [Re: SCATPACK 1] #1667674
09/05/14 09:14 PM
09/05/14 09:14 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Had one.....Talk about distribution issues....Mine I modded the heck out of, and still wasn't great. Made a full plenum 1" spacer, had one inch spacers under the carbs, had all the runners blended for shorter turn radius'...Carbs were modded as well. Jets & squirters were all hand drilled to my sizes and no chokes or anything. If I was going to keep it, I would have been making my own stepped metering rods for the carbs. Could never get them perfect.
Re: Street Hemi Intake recommendations [Re: Dragula] #1667675
09/05/14 09:47 PM
09/05/14 09:47 PM
RUNCHARGER Offline
RUNCHARGER  Offline
Stage V intake is higher for sure, I just can't remember how much. I'm cutting apart a new Six Pack shaker base right now as a matter of fact to fit my AVS' on the Stage V. FHO makes a storebought one but my time and welder are free. I already modded the aircleaner lid for the different spacing.
Sheldon
Re: Street Hemi Intake recommendations [Re: RUNCHARGER] #1667676
09/05/14 10:07 PM
09/05/14 10:07 PM
Kingsville, Md
grncpe Offline
grncpe  Offline
Kingsville, Md
Hi, The Stage V is 1/4 to 1/2 higher, The one that Aruza sells has been milled. Call to make sure.I think that is how he sold them a few years ago.I have a cuda with a shaker & a stage V. You don't have much room to run spacers on it. I made 836hp & 730 tq with a stage V with two thunder series carbs, of coarse I have more cubes than you. We also have a 472ci. street car with a stock intake & original carbs…….dont waste your time going that route. Do the stage V with the thunder carbs or scotts & never look back! I would call aruza to ask about the milled intake for extra space.
Re: Street Hemi Intake recommendations [Re: grncpe] #1667677
09/05/14 11:38 PM
09/05/14 11:38 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Interesting,...my Stage V intake was only 1/8" taller than my stock 66-67 intake, & didn't appear to be shaved, & wasn't from John.
Re: Street Hemi Intake recommendations [Re: grncpe] #1667678
09/05/14 11:43 PM
09/05/14 11:43 PM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
I had John's modded Stage 5 with two Eddy 600's on my 434 & did have the
steel ropop shaker base from Tim Banning. Setup worked great. Wish I'd
have gone with the Thunder 650's but we still got the afb's running pretty
smoothly. Shaker fit well & only was bout 1/4"higher than with the
factory setup, but I also had small 1/8"spacers under the carbs.
