Re: Street Hemi Intake recommendations [Re: Triggerfish] #1667679
09/06/14 12:52 AM
09/06/14 12:52 AM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
Fwiw,...Stage V heads,covers,& intake. 650 Thunders. FHO lid. FHO base cut & fab'd on a factory skirt.
Mega K-member,mounts, & brackets.
Clears a flat 70 coronet hood by thiiiiis much.
Re: Street Hemi Intake recommendations [Re: thehemikid] #1667680
09/06/14 04:06 AM
09/06/14 04:06 AM
P
PasiR Offline
PasiR  Offline
P
I modified steel 6-pack baseplate for StageV intake and Edelbrocks. Fits under the hood on my -71 B-body with airgrabber.
Re: Street Hemi Intake recommendations [Re: Hemi ragtop] #1667681
10/13/14 10:34 AM
10/13/14 10:34 AM
Annapolis, MD, USA
V
Vert Offline
Vert  Offline
V
Annapolis, MD, USA
Hemi Ragtop,
I asked Ray Barton about using Holleys on my 528. He told me he could do it, but it required lots of work; carb mods and linkage issues. He didn't recommend it for my application. Using his std formula we got 704HP using the Stage V and two Edelbrocks. Rick Cassell sells the fuel line(#HO300 Hemi fuel line kit that looks factory but fits Edelbrocks with Stage V spacing. $165 when I bought it.
Barton milled 1/2inch off my Stage V intake to buy me some hood clearance (71 Barracuda, Schumaucher mounts, Rallye hood). The Stage V is taller. Dominic did a good comparison vs the Mopar 2x4 when it came out. The intake milling, plus the FHO dropbase barely offset the Schumacher height increase. I have 3/4 max clearance underhood.
Re: Street Hemi Intake recommendations [Re: Vert] #1667682
10/13/14 01:13 PM
10/13/14 01:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If your not a purist,try the Indy modman intake with two Edelbrock carbs and there is two plastic adapters to step up from the small diameter hemi carbs to the larger Edelbrocks.
