Radiator fluid change question #1667550
09/04/14 01:57 PM
09/04/14 01:57 PM
Bradenton, Fl 34203
Kilroy was here Offline OP
Bradenton, Fl 34203
I have a 2008 Mitsubishi Raider (same as 2008 Dakota) with the Dodge 3.7 engine. I bought this truck new.
It just turned 100,000 miles and don't remember adding even a drop of radiator fluid. (The oil change guy probably did, but it's never been low) It has that Orange stuff. Still nice color orange to it. The paper towel is quite clean.
So wadduya think, should I change it, or not mess with success?
Re: Radiator fluid change question [Re: Kilroy was here] #1667551
09/04/14 06:26 PM
09/04/14 06:26 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Get one of those antifreeze testers and see what it says. They aren't but a couple of bucks.
Re: Radiator fluid change question [Re: stumpy] #1667552
09/04/14 06:38 PM
09/04/14 06:38 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
The old traditional ones only tell you is the freezing point.
And he's in Florida.
A coolant test strip that show PH and then Reserve Alkalinity is needed with the newer non green coolants.
A simple electrolysis test reading under 300mV is helpful too.
Re: Radiator fluid change question [Re: autoxcuda] #1667553
09/04/14 07:40 PM
09/04/14 07:40 PM
IN
ahy Offline
ahy  Offline
IN
The chemical tests sound like a good idea. I don't have the equipment... but personally would go ahead and change it with 100k and that many years.
It will cost a few bucks but corrosion damage caused by worn out anti freeze would cost a lot more.
I use Prestone "extended life" on all my classics and DD's. It mixes fine with the red Chrysler stuff. At the same time, suggest you change the T stat and radiator hoses as preventative maintenance.
Re: Radiator fluid change question [Re: ahy] #1667554
09/04/14 07:44 PM
09/04/14 07:44 PM
So Cal
So Cal
Re: Radiator fluid change question [Re: autoxcuda] #1667555
09/04/14 11:04 PM
09/04/14 11:04 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Just pick up some Zerex G-05 from NAPA, flush the system and replace the 'stat (use OEM Mopar), and you'll be good to go for another 100k.
It's Swifty! Swifty, you toad sucker!
Re: Radiator fluid change question [Re: zrxkawboy] #1667556
09/05/14 09:45 AM
09/05/14 09:45 AM
GA
Boosted Offline
Boosted  Offline
GA
bingo!!!!!
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Radiator fluid change question [Re: zrxkawboy] #1667557
09/05/14 09:57 AM
09/05/14 09:57 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
IIRC around 06 they started using an orangeish color that wasnt Dexcool.Its supposed to be good for 100K or around 5 years.Id change it.Just use the new type thats universal.Under no way use DexCool.Rocky
Chrysler Firepower
Re: Radiator fluid change question [Re: therocks] #1667558
09/05/14 10:39 AM
09/05/14 10:39 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
As far as I know the orange stuff is dex cool. It says so on the label. I switched back to dex cool a few years ago, it's the right anti freeze to use today.
To the original poster, I would change it and the thermostat and the hoses at 6 years old. Just like Ahy suggested. I would use dex cool for sure if you want it to last another 5 years.
Re: Radiator fluid change question [Re: Challenger 1] #1667559
09/05/14 11:33 AM
09/05/14 11:33 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
DexCool is total crap.Ive flushed so many GMs with plugged systems its unreal.The newer stuff is extended life and is not DexCool.Id say in 50 cars with Dex only one got it back in.Then it was customer request.Others all got the new universal type.Thats all we run.If you look at new cars coolant is many colors.Some is even red.Rocky
Chrysler Firepower
Re: Radiator fluid change question [Re: Challenger 1] #1667560
09/05/14 07:16 PM
09/05/14 07:16 PM
Ohio
john55 Offline
john55  Offline
Ohio
...and mix with DISTILLED water, not tap water
The Plymouth Win You Over Beat Goes On
Re: Radiator fluid change question [Re: Kilroy was here] #1667561
09/05/14 07:31 PM
09/05/14 07:31 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Don't use dex cool at all. Use the proper coolant which is a HOAT coolant.Zerex Z-05 or the Mopar stuff will work.
Nautilus Racing-
Re: Radiator fluid change question [Re: Chris2581] #1667562
09/06/14 09:34 AM
09/06/14 09:34 AM
Bradenton, Fl 34203
Bradenton, Fl 34203
thanks all for the replies.
Re: Radiator fluid change question [Re: Chris2581] #1667563
09/06/14 11:31 AM
09/06/14 11:31 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
This. Though many don't believe it, the vast majority of the "universal" coolants are Dex-clones, meaning they are either Dex-cool or very, very close. Most of them are OAT (like Dex-cool) instead of HOAT (like G-05) and contain 2-eh, the plasticizer which caused all of the GM LIM gasket failures. The only exception is Peak Global Lifetime, which does not contain 2-eh, though it's sibling, Peak Long Life, does. Prestone AMAM is another Dex-clone. Check the MSDS under Section 2, Composition, and you'll see 2-eh: http://econtent.autozone.com:24999/znetcs/msds/en/US/391379
