Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666080
01/09/15 09:49 PM
01/09/15 09:49 PM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Porter prepped stealth heads, straight plugs.
Just an update, Talked to Dwayne yesterday, ported Stealth heads almost done. We talked quite awhile about cam ideas. We settled on a couple of comp lobes with similar intake specs as mopar .528 with faster ramp & a little more lift. Exhaust a little more lift/duration but not much. Wide centers. In theory it should run pretty strong but the bonus is tight lash & nitriding as insurance. Dwayne is great to talk to & very knowledgeable, I can see why he's so well respected. I'll keep you posted on how it runs. BTW, I managed to get my Bee down here from storage last weekend. Its like being reunited with an old friend!
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666081
01/09/15 10:50 PM
01/09/15 10:50 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You should have priced a Herbert roller kit.
Re: The other 451, cam choice w/manifolds? [Re: FastmOp] #1666082
01/10/15 02:20 AM
01/10/15 02:20 AM
Way North Idaho
1KoolBee Offline OP
1KoolBee  Offline OP
Way North Idaho
Why? Do they have a grind proven to work well with factory exhaust manifolds?
Re: The other 451, cam choice w/manifolds? [Re: 1KoolBee] #1666083
01/10/15 02:36 AM
01/10/15 02:36 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
I'm guessing it was a joke,based on a cheap antique roller setup VS. a flat tappet with nitriding etc in hopes of a cam that doesn't fail shortly after fire up?? Hope things work out well for you.
