What 6.1 hemi should I use ??? 69 Charger #166575
12/12/08 02:48 PM
12/12/08 02:48 PM
Marilla, New York
RalleyA12 Offline OP
Marilla, New York
I plan on installing a 6.1 Hemi in a 1969 Charger. I plan to start looking in my local wrecking yards for one. My question is, is one version better than another ( Charger, Jeep etc. )? I mean will one from a particular model work better than another as far as the location of the pulleys and where the power steering, A/C, and alternator are located. I seem to remember a post saying that the 5.7 truck engines worked/fit better in the older cars because of where PS, A/C, and alternator were. Can you switch the pulleys from a 5.7 to a 6.1 ?
Re: What 6.1 hemi should I use ??? 69 Charger [Re: RalleyA12] #166576
12/12/08 09:35 PM
12/12/08 09:35 PM
Portland,OR
rjsjea Offline
rjsjea  Offline
Portland,OR
All the 6.1's are the same. Except the Jeep SRT8 has different exhaust manifolds which tuck closer to the block.
The front accessories can be swapped from a 5.7 to a 6.1. It has a front cover which can be swapped. The 6.1 mounts the AC compressor and Alternator down low, causing some issues. Pretty easy to overcome from what I have read, plus they look cool mounted down low
I used the AlterK so it was no problem fitting the 6.1 w/ headers in an Abody
