Need a Pro Street Wiring Harness for a Cuda.... #1664864
08/28/14 04:45 PM
08/28/14 04:45 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
I am looking for an all in one fuse block with all the relay's for all the Pro Street stuff as well as the OEM stuff right to each componant.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664865
08/28/14 05:49 PM
08/28/14 05:49 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: DusterDave] #1664866
08/28/14 10:57 PM
08/28/14 10:57 PM
Dragula Offline OP
Dragula  Offline OP
http://www.americanautowire.com/view-product/1970-74-barracudachallenger-kit/
Affordably priced, too!
I don't know...It has bulk head connector and my prostreet car no longer uses those....
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664867
08/29/14 05:51 AM
08/29/14 05:51 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Try Painless............used a few of theirs, no problems
Monte
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Monte_Smith] #1664868
08/29/14 11:21 AM
08/29/14 11:21 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Monte_Smith] #1664869
08/29/14 12:26 PM
08/29/14 12:26 PM
Dragula Offline OP
Dragula  Offline OP
Monte
Called them...Was not real happy with them over the phone...One size fits all attitude.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664870
08/29/14 12:30 PM
08/29/14 12:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Monte
I`ve installed a few in the last couple of years and they`re ok but heard the Francis(sp)is one of the best from those in the know. One Painless we did actually had the rear lights wired wrong.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Thumperdart] #1664871
08/29/14 12:50 PM
08/29/14 12:50 PM
Dragula Offline OP
Dragula  Offline OP
I was looking at the Francis ones, I did not have time to call them yet. I like what I read about those the best so far. My car has some stockish stuff, but other areas not so much, and its not going to be an easy find I think.
The Painless one had all the stock stuff built in like wiper motor, heater motor, etc...I don't need any of that, but I do need a lot of relay's built in for all the Prostreet stuff. Would prefer the relay's built into the main block.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664872
08/29/14 12:58 PM
08/29/14 12:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
We ended up cutting over 1/2 of the wiring out of the fuse/relay block for the same reasons.................didn`t need most of what the "basic" Painless kit came with and the Francis is supposed to be more versatile but again, just repeating what I heard.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664873
08/29/14 01:43 PM
08/29/14 01:43 PM
Corvallis,OR
540CUDA Offline
super street
540CUDA  Offline
super street
Corvallis,OR
The Ron Francis kits are made to suit. I went with them after not having the greatest experience with painless a few times. When you call them they will tailor the fuse block and circuits to your needs. Its pretty cool. I used the 24/7 setup, the kit for my truck was about $900.00. Set up for power windows, AC, fuel pumps,fans,stereo... all the usual hot rod stuff. Plus you will also get a schematic of YOUR system to keep for future reference.
PRH 540,T-ram,-1's tagged and insured. 9.24et 146.13mph 1.30 60'3300#s
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664874
08/29/14 02:03 PM
08/29/14 02:03 PM
Arlington, Tx.
BJS racing Offline
BJS racing  Offline
Arlington, Tx.
That is the hardest thing to find is a harness set up that will have everything the way you want it when you have a Pro Street application. I am sorry we didn't have everything you were looking for in one package. I don't really know anyone that has everything you were looking at with out having way more than you need. There is only one other option that I know of that we offer other than what you and I talked about yesterday. Our 10144 harness would possibly be a little closer but it doesn't have the turn signal wiring in it.
http://www.painlessperformance.com/webcatalog/p.php?s=10144&sb=Go%21
The only thing I could say is just about anywhere you go you are likely going to have to have either way more than you need or have to put two different part numbers together to get every thing to work like you want.
Back in the swing of things at Painless again! Great to be back!
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664875
08/30/14 03:14 AM
08/30/14 03:14 AM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
This was a problem I am having w/my Belvedere. I bought the painless dash mount 4 toggle system but was not happy w/how they had the start button wired(hot all the time). I changed that and the fuel pump circuit so that I have to flip one switch before either are hot.
Then I find out my factory harness(headlights and taillights)was jacked and now I need to get a 4 circuit set up(headlights, taillights, breaks and turn signals). Yeah try locating that. On Tuesday I will call Auto Wiring Solutions(they have a 4 circuit) and see if this will work.
Ok
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: cudatom] #1664876
08/30/14 10:18 AM
08/30/14 10:18 AM
moparx Online content
moparx  Online Content
without sounding like azzz, maybe with only needing 4 circuits, just wire it from scratch ? i have done 5 projects like that using a couple of "universal" type schematics,[with way more circuits than you need] and although it took some time to do, it was quicker and cheaper in the long run after you figure in the cost and time combining 2[or more] kits from different manufacturers to get just the right combination of circuits with the correct wire gage and relay combo[s]. just my experiance and opinion.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: moparx] #1664877
08/30/14 08:47 PM
08/30/14 08:47 PM
Dragula Offline OP
Dragula  Offline OP
A lot of my factory wiring that is still stock is just quiting on me. So I need it re-wired right to each and every componant...I can't take all the factory stuff just quiting all the time. The bulbs look like flash cubes some days.
My prostreet stuff is all wired with weather pack connectors and relays and has been working good, but its a mish mash of an ARC switch panel and divorced relay's and just a mess with the factory wiring under the dash...Would like to make eveything one unit for power for eveything..
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664878
08/30/14 09:42 PM
08/30/14 09:42 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
That's how mine was...A combination of stock and after market. I finally pulled out every wire from bumper to bumper, kept the pigtails for the lights and ended up with this. A few more wires/cables have been added, but you get the idea. I have separate relays for the big AMP items (Fuel pump/fan etc...) close to the source
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Adobedude] #1664879
08/30/14 10:43 PM
08/30/14 10:43 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Now THAT is a clean and easy to service electrical system! Excellent job!
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Adobedude] #1664880
08/30/14 11:18 PM
08/30/14 11:18 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Very nice and what I was planning on doing. I will keep the pigtails and run a new harness. I find that the factory harness has wires running all over the place. Jumping from one group of wires to another. By removing it all and starting from scratch makes for a neater set up. Also makes it nice to get everything from one place, relays, wires, fuse block. For someone that doesnt do a lot of wiring its nice to talk w/someone that does and discuss what you have, what your plans are and what results you want.
Ok
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Adobedude] #1664881
08/31/14 12:40 PM
08/31/14 12:40 PM
Dragula Offline OP
Dragula  Offline OP
Pretty much what I want to do....An entire system all in one spot, ignition, fuse box, relay's, circuit breakers, and Arc switch panel, aftermarket gauges, etc All with wire lables as I intend to purchase a labeler...What is the big power distribution block at the bottom lower left? I will need at least three I think. One for high power direct connection, a switched and one for all the grounds.
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664882
08/31/14 03:39 PM
08/31/14 03:39 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I wire a lot of cars and I think you are way over thinking this deal. Wiring a car from scratch is actually pretty easy if you have an understanding of how things work, have some patience and mostly have a PLAN.
For relays and stuff, MANY companies have very nice relay centers already set up and you just terminate from there. I personally use the ones from "Leash" electronics. You can order with any mix of ground or hot relay outputs if desired. It is potted, fused and ready to go.
For a ground, you can do your own "floating" ground setup. Take a strip of fairly thick copper, about an inch wide and six inches long. Put several 3/8 and 5/16 holes in it. These will be your ground lugs. Now mount the strip to the chassis on rubber isolators. The ground cable comes from battery to strip and all items ground to strip. A "to the chassis" ground system is actually one of the poorest setups you can have, yet people continue to do it and wonder why they have wiring issues.
I wire most everything with the "floating" setup I described above, but especially on EFI cars, where clean grounds and RFI noise are big concerns
This is a dragster bulkhead I wired a couple years ago with a nice Painless relay and fuse center. We spread the stuff out over the bulkhead, that in case of an issue it would be easy to look at and diagnose
Monte
Re: Need a Pro Street Wiring Harness for a Cuda.... [Re: Dragula] #1664883
08/31/14 04:06 PM
08/31/14 04:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure looks nice ... but WHY put all the relays there..
relays should be near the draw and run a small trigger wire
