Wood Floor Board to Metal? #1664625
08/28/14 01:27 AM
08/28/14 01:27 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
My 37 (and I guess all of these trucks) has a wood floorboard. I think I'm going to make a metal one to replace it. Has anyone else done this too?
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Wood Floor Board to Metal? [Re: AZ_A12_BEE] #1664626
08/28/14 02:49 PM
08/28/14 02:49 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
i didn't replace mine with metal in my 42 truck, but i coated both sides of the wood with bedliner.that way it still sits flush with the floor and it's protected better now.
Re: Wood Floor Board to Metal? [Re: AZ_A12_BEE] #1664627
08/28/14 09:17 PM
08/28/14 09:17 PM
Escondido, CA. Ron Podsiadly,...
Mopar Ron Offline
Mopar Ron  Offline
all the time
I usually use 1x1" tubbing as a frame work and the place metal over it. works out great and its srtong too.
Re: Wood Floor Board to Metal? [Re: Mopar Ron] #1664628
08/29/14 12:44 AM
08/29/14 12:44 AM
Dreaming of the 808
Dreaming of the 808
all the time
Ron, that's what I was thinking, do you weld it in or leave it removable?
Re: Wood Floor Board to Metal? [Re: AZ_A12_BEE] #1664629
08/29/14 02:24 PM
08/29/14 02:24 PM
Mopar Ron Offline
Mopar Ron  Offline
I usually weld them in but you could just as well make it bolt in like the wood did..
then when you change it over to a mopar you could just modify the piece if you have to Ron...
Re: Wood Floor Board to Metal? [Re: Mopar Ron] #1664630
08/29/14 02:52 PM
08/29/14 02:52 PM
Dreaming of the 808
Dreaming of the 808
God advice, thanks Ron, I will just bolt it in for now
Re: Wood Floor Board to Metal? [Re: AZ_A12_BEE] #1664631
08/30/14 10:50 PM
08/30/14 10:50 PM
AZ
Mike P Offline
Mike P  Offline
AZ
For what it's worth, I'd definitely make it bolt in for now. Depending on the engine and transmission you swap in later you may end up having to completely redo it in the future.
The PO of mine had pretty much butchered the firewall and toe board so I was starting from scratch. The set back and height of my engine required a hump. When I did the original mockup on it I was planning on using a 727 and the floor didn't need much of a rise, that changed when I decided to use a 518.
I built my floor and new toe board out of some stainless I had laying around. I originally made it bolt it (I used nutserts and 1/4-20 bolts). As the mockup is pretty complete I eventually did go ahead and weld it in.
There are some pictures of mine in my build thread.
https://board.moparts.org/ubbthreads/show...part=1&vc=1
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
