Wood Floor Board to Metal?
#1664625
08/28/14 01:27 AM
08/28/14 01:27 AM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
My 37 (and I guess all of these trucks) has a wood floorboard. I think I'm going to make a metal one to replace it. Has anyone else done this too?
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
Re: Wood Floor Board to Metal?
[Re: AZ_A12_BEE]
#1664627
08/28/14 09:17 PM
08/28/14 09:17 PM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
all the time
I usually use 1x1" tubbing as a frame work and the place metal over it. works out great and its srtong too.
[Re: AZ_A12_BEE]
#1664631
08/30/14 10:50 PM
08/30/14 10:50 PM
Posts: 1,510 AZ
Mike P
AZ
For what it's worth, I'd definitely make it bolt in for now. Depending on the engine and transmission you swap in later you may end up having to completely redo it in the future. The PO of mine had pretty much butchered the firewall and toe board so I was starting from scratch. The set back and height of my engine required a hump. When I did the original mockup on it I was planning on using a 727 and the floor didn't need much of a rise, that changed when I decided to use a 518. I built my floor and new toe board out of some stainless I had laying around. I originally made it bolt it (I used nutserts and 1/4-20 bolts). As the mockup is pretty complete I eventually did go ahead and weld it in. There are some pictures of mine in my build thread. https://board.moparts.org/ubbthreads/show...part=1&vc=1
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
