68-70 B body gas tank vent lines dripping gas #1664433
08/27/14 06:20 PM
08/27/14 06:20 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I have had many B bodies and they all seem to like to drip gas out the vent lines when the tank is full on hot days.
The line that runs up into the trunk is usually no problem but the short line that clips to the crossmember likes to vent out gas. Anyone have a good cure for this? I plan to just make a new line that runs higher up to get it further above the fuel level.
And yes the lines are clear.
I recall someone mentioning the lines may need to be swapped.
Re: 68-70 B body gas tank vent lines dripping gas [Re: demon] #1664434
08/28/14 10:59 AM
08/28/14 10:59 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
don't fill it so much and or get a vented gas cap.
Coming soon!!!!
Re: 68-70 B body gas tank vent lines dripping gas [Re: demon] #1664435
08/28/14 11:07 AM
08/28/14 11:07 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I have read that here several times that on some of the repo tanks had the vent nipples changed up. I'd try switching the lines and see if it get's better.
Re: 68-70 B body gas tank vent lines dripping gas [Re: Challenger 1] #1664436
08/28/14 11:09 AM
08/28/14 11:09 AM
roanoke va
kbcuda Offline
kbcuda  Offline
roanoke va
That worked for me!
