'72 RR heater core removal?
#1664413
08/27/14 05:23 PM
08/27/14 05:23 PM
Posts: 2,934 Finalnd, Perkele
jyrki
Finalnd, Perkele
I should take the heater core repaired in our 72 roadrunnr, what's the easiest way to remove it?
Plynouth VIP '67 TT IC EFI
Re: '72 RR heater core removal?
[Re: jyrki]
#1664414
08/27/14 10:38 PM
08/27/14 10:38 PM
RapidRobert
First I would take off the heater hoses from the eng side firewall and replace em with some junk hoses and run some water thru the core to get all the antifreeze out to minimize the antifreeze mess on your inside parts/carpet (first put a thick towell under the box). Take the small thin plate/phillips screw that is on the firewall securing the nipples where they come thru the firewall (if it has one). On the inside I have no specific info I would just take off the cables and wires etc & possibly the glove box so you can work the heater box back & tilt it to let the nipples come thru the firewall
[Re: jyrki]
#1664416
08/28/14 09:38 AM
08/28/14 09:38 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
In addition to what Robert said, there are 4 or 5 bolts under the hood on the firewall that need taken off. There is a bolt on top of the heater box inside the car that needs undone, the vacuum hoses, a couple of electrical connectors, the cable from the heater/ac control panel. It is a lot easier if the front seat has been removed from the car.
Under the hood are the heater hoses and the a/c hoses if you have a/c. If you have a/c and it was working, you may want a shop to vacuum out the refrigerant.
When I do the heater cores, I replace the A/C evap too. It is such a chore to take out the box, the extra $350 for an evap core is worth it.
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
