Page 43 of 47 1 2 41 42 43 44 45 46 47
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16642
07/29/06 10:05 PM
07/29/06 10:05 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Ok, finally figured out why this thing wouldnt start---the ECU died. So i plugged in a gold box i had and viola. Runs good, need to finish up some details but im just about ready for the first road test .
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16643
07/29/06 10:56 PM
07/29/06 10:56 PM
Lemont, IL
Not_A_Blazer Offline
super gas
super gas
Lemont, IL
Well,a little update on the D100,
nevermind
Re: why isn' there much written about 81to 90 2wd truck [Re: Not_A_Blazer] #16644
07/30/06 09:51 PM
07/30/06 09:51 PM
Well, its running and moved under its own power. However i seem to have some ignition troubles while trying to get this thing tuned. https://board.moparts.org/ubbthreads/show...e=1#Post2808108
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16645
07/30/06 10:39 PM
07/30/06 10:39 PM
Ontario Canada
Webster Online content
Webster  Online Content
Ontario Canada
Hope you get it straighten out......And by the way are you Married yet??????
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16646
07/30/06 11:20 PM
07/30/06 11:20 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I am going to assume you have the solid state voltage regulator, check the voltage readings at the box, at the battery, and in and out of the ballast resistor.
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16647
07/31/06 07:36 AM
07/31/06 07:36 AM
No, not married yet. A little less than 3 months.
What am i looking for as far as voltages? It has 14-14.5 volts at the battery when running. Is it to much? I was thinking it was a hair on the high side, but it leveled off and didnt really go past that. This is the new nip alt as it came on the magnum motor. Unfortunatly i have to buy another box just to get it running again to diagnose it.
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16648
08/02/06 08:05 PM
08/02/06 08:05 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
That's not too high. I am not sure if you are using a carb and electronic ign, but if ya are I would consider doing the hei module swap and a true 12 volt coil for hotter spark!
84 D150 440/727
79 /6 swb D150
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16649
08/05/06 12:17 AM
08/05/06 12:17 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Pokey, did ya get the truck weighed yet?....Where ya been?
O.G.
84 D150 440/727
79 /6 swb D150
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16650
08/05/06 01:14 AM
08/05/06 01:14 AM
Ontario Canada
Ontario Canada
Yea where did everyone go.....Must be the summer. We are all outside..
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16651
08/05/06 01:55 AM
08/05/06 01:55 AM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
nope not weighed yet been too gosh darn busy hopefully tomorrow, im interested to see if the numbers i have been getting on my new gadget change much so far im showing net horsepower at 170 and net torque at 220, sounds low but it is "net" that it reads so the numbers are low
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16652
08/07/06 01:13 AM
08/07/06 01:13 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Glad to hear ya are still out there Pokey! You too Webster!
I have been busy too, workin' and doin what I can to get the new six together...doin efi wiring now, and getting all the turbo plumbing worked out.. .header is done,6 into two into one... tubes are really short, less than a foot! The intercooler business is becoming a nightmare tho. The tubing is pretty long. Hoping I dont have problems with lag. The cooler is mounted behind the front bumper, on the driver's side.
yeah, yeah, I will get pix...
O.G.
84 D150 440/727
79 /6 swb D150
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16653
08/08/06 01:55 AM
08/08/06 01:55 AM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
good to hear your still goin strong! i might be needing your expertise with the six's my dad is lookin into a 70 stepside with a slant in it , I'll let you know
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16654
08/09/06 12:56 AM
08/09/06 12:56 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Cool!
I am there!
O.G.
84 D150 440/727
79 /6 swb D150
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16655
08/09/06 10:29 PM
08/09/06 10:29 PM
This was my turbo setup----just in a dart though......
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16656
08/09/06 10:43 PM
08/09/06 10:43 PM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
That exhaust pipe running right next to the distributor may have gotten interesting at times. Eh.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
Re: why isn' there much written about 81to 90 2wd truck [Re: shinnery] #16657
08/10/06 03:10 PM
08/10/06 03:10 PM
Its alot further a way than it looks, the head on the one wastegate was pretty close however.
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: 85_Ram_4speed] #16658
08/11/06 12:09 AM
08/11/06 12:09 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Cool!
I have plumbed everything at least 2 different ways, but am gettin there.
My goal is easy access to everything, without having intercooler tubing too long. Lots of space with a slant in a truck!
84 D150 440/727
79 /6 swb D150
Re: why isn' there much written about 81to 90 2wd truck [Re: old_goat] #16659
08/11/06 10:29 PM
08/11/06 10:29 PM
Utah
pokey1 Offline OP
mopar addict
pokey1  Offline OP
mopar addict
Utah
so now im thinkin about a 100 shot of nos, any opinions about that?
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16660
08/11/06 10:40 PM
08/11/06 10:40 PM
Not big enough. Go for 150 or more
Outcast Dodge guy.
Re: why isn' there much written about 81to 90 2wd truck [Re: pokey1] #16661
08/12/06 03:06 AM
08/12/06 03:06 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
100-150 works for a slant....if ya have a stout enough bottom end...good for a bigblock too, for that extra punch.
Careful with that stuff tho! I trashed more than one 4 cyl......
O.G.
84 D150 440/727
79 /6 swb D150
