70 dash gauge circuit board issues #1663917
08/26/14 01:26 PM
08/26/14 01:26 PM
70GTXer Offline OP
70GTXer  Offline OP
have a cluster reworked by Bob's Speedo in Michigan. Have isolated my erratic readings to a bad voltage limiter only providing 2 volts. wanting to know which replacement circuit board members have been using. have found 2 that the limiter has been replaced with digital circuits, can anybody tell me the difference and which one in more reliable.
Thanks Moparts and all members
Re: 70 dash gauge circuit board issues [Re: 70GTXer] #1663918
08/26/14 01:38 PM
08/26/14 01:38 PM
Just me I would get a good used circuit board (if needed) and an electronic VL. I think RT specialties offers one and & I think it is an easy electronic conversion that is easily done by soldering a few resistors etc inside the OE can (I'd Google the instructions)
Re: 70 dash gauge circuit board issues [Re: RapidRobert] #1663919
08/26/14 05:26 PM
08/26/14 05:26 PM
Andrewh Offline
Andrewh  Offline
built my on solid state vr based on the tech archive article here.
been working for a few years now.
might have been 5 bucks in parts at radio shack.
Re: 70 dash gauge circuit board issues [Re: Andrewh] #1663920
08/26/14 06:45 PM
08/26/14 06:45 PM
Oklahoma City OK
Cudajon Offline
Cudajon  Offline
Oklahoma City OK
I built my own to. But, when I was roaming Pull-a-part junk yard I found that the 80's Dodge trucks and vans used an electronic VR. If its got analog gauges it probably has one. I need to find a part number sometime when I got time. I've never seen a circuit board like that before. Here's a pic of a 72 Instrument cluster Rally Gauges. It sure don't look like that one.
Re: 70 dash gauge circuit board issues [Re: Cudajon] #1663921
08/26/14 07:01 PM
08/26/14 07:01 PM
Andrewh Offline
Andrewh  Offline
that is interesting. seems like the change over is 88.
87 and down seem to be the standard like we have. 88 and up are electronic.
Part # VRC601
little pricey at 33 bucks at rock auto.
or you can pick up the autozone version for 45 with lifetime warranty.
of course I could be wrong and it is just a generic blurb in the description.
Our electronic voltage regulator PC boards are encapsulated in epoxy to deliver improved performance and resistance to failure that may be caused by vibration and corrosion of electrical connections
