Re: 440 "lunging" at low speed
[Re: 70VERT]
#1663714
08/26/14 01:01 AM
08/26/14 01:01 AM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Are you down around idle when this happens?
[Re: 70VERT]
#1663716
08/26/14 10:04 AM
08/26/14 10:04 AM
Posts: 1,565 tennessee
pushbutton
tennessee
My 70 Plymouth 440 (4 speed) has been "lunging" when I coast at low speeds. It idles fine and runs out great through the gears. Only time I notice it is when I am 2,3, or 4th and just kinda coasting at low speeds.....440, Holley 750 Street Avenger,stock heads, Edelbrock Performer manifold and Hughes Whiplash cam. Can you guys give me some advice on what might be going on here and how to straighten it out? Thanx
Do you have the vac advance hooked up? If you do try disconnecting and plugging the hose. See if it helps.
[Re: 70VERT]
#1663717
08/26/14 10:59 AM
08/26/14 10:59 AM
RapidRobert
Clarify the lunging: are you coasting down with foot off of the pedal. Are you at a steady speed. what RPM/how much throttle (load/in hg)
[Re: 70VERT]
#1663718
08/26/14 02:36 PM
08/26/14 02:36 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
Do you have a tach in the car? If os go drive it and give us the RPM it does the surging at, is the clutch out or in also ?
[Re: Cab_Burge]
#1663719
08/26/14 02:45 PM
08/26/14 02:45 PM
Posts: 15,894 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
RapidRobert and PushButton have some good thoughts here. If you are on the gas still (although coasting doesn't sound like it but clarify please) I think PushButton has a good suggestion. I had some lunging or surging on one of my 360's that went away when I started running it w/o the vac advance connected.
If not on the gas, and in 4th or even 3rd, then it does sound like you may be in too high a gear.
Facts are stubborn things.
[Re: 70VERT]
#1663720
08/26/14 04:06 PM
08/26/14 04:06 PM
Challenger 1
Cincinnati, Ohio
440+750carb=lean. My guess is a lean surge is what your experiencing. Just my guess. Jet it up some and see if I'm right. When you unplug the vacuum advance you are just applying a band aid and missing out on good cruise power and mileage.
[Re: Challenger 1]
#1663725
08/27/14 02:29 AM
08/27/14 02:29 AM
Posts: 553 DE
Ply72rr
DE
Unplugging the vacuum advance to see if the surge goes away could be a good test, if it does stop the surge maybe an adjustment to the Vacuum advance with a allen wrench would take care of the problem. The instructions that came with my MP ignition kit mentioned a low speed surge could be caused by this.
[Re: Ply72rr]
#1663726
08/27/14 10:52 AM
08/27/14 10:52 AM
Posts: 5,163 CT
GTX MATT
CT
You're at 1000 rpm or less at 10 mph in second gear, I think your problem IS that you need to downshift. Additionally this is not a stock engine, and doesn't pull as much vacuum at that speed. More initial timing might help it.
[Re: 70VERT]
#1663727
08/27/14 11:11 AM
08/27/14 11:11 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Basically, it's at low RPMs with very little throttle. For instance 2nd gear around 10mph, it'll surge up and down enough to clang the drive train. 3rd gear comparable only at a little higher speed. I know enough when to downshift, thats not it.
Why are you in second gear at 10mph with 3.55's ???
[Re: Challenger 1]
#1663728
08/27/14 11:11 AM
08/27/14 11:11 AM
Posts: 323 Endicott, NY, USA
crazyjjk
Endicott, NY, USA
I would also be inclined to believe it is a lean surge.
