Re: Dakota Drop Spindles [Re: 76dodgeboy] #1663607
08/31/14 02:09 PM
08/31/14 02:09 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Those were 2600's you had before weren't they Harry?
Re: Dakota Drop Spindles [Re: 76dodgeboy] #1663608
08/31/14 03:20 PM
08/31/14 03:20 PM
MO
C_Notch Offline OP
C_Notch  Offline OP
MO
"2600 is 87-90
2605 is 91-96"
My mistake. mine are the 2605's
Re: Dakota Drop Spindles [Re: C_Notch] #1663609
09/02/14 04:38 PM
09/02/14 04:38 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Yes mine are the 2600.
Re: Dakota Drop Spindles [Re: 76dodgeboy] #1663610
09/24/14 03:47 PM
09/24/14 03:47 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
Info from ElPolako at Industsrial Chassis:
"We have found that if you use the BellTech spindles, you are limited to the stock Dakota rotors. The D-series truck rotors will hit the tie rod. BellTech has not only raised and shortened the steering arm, but now have moved it outboard. This has caused an interference issue, we have not had this issue with the spindles from Airbagit."
http://www.industrialchassisinc.com/?page_id=281
Greg
