Page 2 of 4 1 2 3 4
Re: Are COMP cams junk? [Re: Mebsuta] #1662489
08/23/14 09:39 PM
08/23/14 09:39 PM
Khemi, Stygia
Mebsuta Offline
Mebsuta  Offline
Khemi, Stygia
Will a stock 383 really go down the street any faster with an Xtreme cam instead of the vintage pattern? I need to know before I pull mine out.
68 Roadrunner. 383 4-spd. Beat up.
Re: Are COMP cams junk? [Re: Kern Dog] #1662490
08/23/14 09:41 PM
08/23/14 09:41 PM
Nevada
dezduster Offline
dezduster  Offline
Nevada
A friend of mine purchased a complete K kit for a big block chevy. Nothing was left out for info on its intended use or its specifications. Two months and maybe 1500 miles a clatter began inspections revealed their push rods balls were being pushed inside of the PR tubes. The parts boxed and returned pictures taken before being sent back. Some how these push rod tips heated the tubes enough to not gall the balls but fatigue the tube material.BS! They chose to do nothing about the obvious problem of the tubes being over heated upon build only 3. New Lunati push rods installed and all was well for a week. Then the HYD ROLLER lifters on the other bank became noisy. So a call to comp and what is there reply obviously you installed and broke in incorrectly. SOOO new Lunati cam, lifters, springs and push rods went in and its going on 9 months no issues. COMP ADVERTISERS ARE GREAT but they don't live up to the hype it seems.
Re: Are COMP cams junk? [Re: dezduster] #1662491
08/23/14 10:01 PM
08/23/14 10:01 PM
GoDartGo Offline
GoDartGo  Offline
I would tend to agree with the bad Comp lifter theory.
I know I'll get boo'd, but I like Summit house cam and
lifters. I've had two in my 360 with NO problem what
so ever.
If I ever put another cam in, I will go with a solid lifter
that has the laser drill hole in the bottom. Not sure
of the brand.
Re: Are COMP cams junk? [Re: 69/70 Plymies] #1662492
08/24/14 11:30 AM
08/24/14 11:30 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Life used to be so simple.
You called Iskendarian and talked to Ed...
Re: Are COMP cams junk? [Re: Commando1] #1662493
08/24/14 12:01 PM
08/24/14 12:01 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
or Racer Brown........ The SSH-25 and the SSH-44, still two of the best Mopar cams IMHO
Re: Are COMP cams junk? [Re: 6PakBee] #1662494
08/24/14 01:44 PM
08/24/14 01:44 PM
midwest - USA
69/70 Plymies Offline OP
midwest - USA
I've heard from a couple local motorheads that Isky cams are good. I'm wondering why I have not heard much replies on this forum about the Mopar Purpleshaft cams??? I'm hoping for more feedback today!
Re: Are COMP cams junk? [Re: Commando1] #1662495
08/24/14 01:50 PM
08/24/14 01:50 PM
midwest - USA
midwest - USA
Commando1, that's a great statement. Where did the good ol' days go! By the way, where did Ed go?
Re: Are COMP cams junk? [Re: 69/70 Plymies] #1662496
08/24/14 02:00 PM
08/24/14 02:00 PM
he retired some time ago, his two sons, Ron and Richard run the business now Thay haven't done much research and develoment in a lot of years on thier cams in todays world of racing if your not going forward your going backwards
Re: Are COMP cams junk? [Re: Cab_Burge] #1662497
08/24/14 02:09 PM
08/24/14 02:09 PM
wisconsin united states
K
keith airgrabber Offline
Right in the Nutz!!!
K
How do you break in a cam anyways? Doesn't it break in with the motor automatically. I am gonna need to know this when I start my motor for the first time very soon. I am running a comp cam also.
Re: Are COMP cams junk? [Re: keith airgrabber] #1662498
08/24/14 02:12 PM
08/24/14 02:12 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Have it setup so it fires right away and vary the revs a bit but keep them above 2000RPM for the first 30 minutes of run time. Lots of breakin lube on the lobes and lifter faces, oil on the sides of the lifters and make sure the lifters are free to spin in their bores before starting. If you have dual valve springs, take the inners out for cam breakin.
Sheldon
Re: Are COMP cams junk? [Re: RUNCHARGER] #1662499
08/24/14 02:19 PM
08/24/14 02:19 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Plus you need an oil with the proper chemistry for flat tappet
protection, normal car oil for modern cars cannot protect a flat tappet cam.
You'll need to add ZDDP or other additive for this.
Also you can choose to use one of the many oils advertised for that specific purpose, I use Valvoline VR-1, but there are others.
VERY IMPORTANT!!!
Joe
Re: Are COMP cams junk? [Re: jlatessa] #1662500
08/24/14 03:05 PM
08/24/14 03:05 PM
Central TX
roe Offline
roe  Offline
Central TX
I don't know if they're junk, I've always heard pretty good things about them on here. I did just read an interesting article in the July issue of MM. They used a short duration, fast lobe/high lift hydraulic roller and were able to get the best of both worlds when it comes to cam qualities. It gave them the smooth (sleeper) idle with high vacuum and still provided the same power as a long duration, choppy idle, low vacuum flat tappet. It was a really informative read for me seeing as I don't know jack diddly about cams so I feel like I learned something.
roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Are COMP cams junk? [Re: 69/70 Plymies] #1662501
08/24/14 03:13 PM
08/24/14 03:13 PM
midwest - USA
midwest - USA
I could really use some reports how the Purpleshaft cams (268/284 duration .450"/.458"lift) have worked out in stock intake/exhaust/rockers on 383HP rebuilds with 4 speed 3.23 gears. But reports on any cam also welcome!
Re: Are COMP cams junk? [Re: roe] #1662502
08/24/14 06:40 PM
08/24/14 06:40 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
About 7-8 yrs back when I bought my XR-280 Comp...my speed shop guy warned me against Hydraulic cams because the factory was using less nickel in the foundry process. Premature wear and failure. He said the only cams (at the time) still worth purchasing were Roller cams. I had bought it for my 505 but I am not anywhere close to building it. I bought the X-treme Energy Roller and matching lifters. I imagine with the EPA being the way it is, my model bumpstick is better than the same model on the shelf today
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Are COMP cams junk? [Re: Pyper70] #1662503
08/24/14 06:48 PM
08/24/14 06:48 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Hearing people complain about noise from their cam cracks me up. These are classic cars that we build to be faster and quicker than they were new. Some compromises are to be expected. Old cars have more vibrations, noise from roof rain gutters, less sound deadening in the floors, etc.
I don't mind a bit of all that. It makes me feel more involved in the experience. A car with no sound or vibration is akin to watching an "in-car" video on a muted TV.
No thanks, I like my cars to be real.
Re: Are COMP cams junk? [Re: Kern Dog] #1662504
08/24/14 10:03 PM
08/24/14 10:03 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
a note on break-in. As said, you want everything set up so it fires and runs ASAP, and can keep running for 30 minutes at ~2000 RPM. This means more timing usually, and have a BIG FAN and a hose nearby to keep it cool.
Fresh engines tend to run warm (more friction) and sitting there working the throttle, setting the timing, checking for leaks, having the headers or manifolds cook off, you really don't want the cooling system overheating too.
Re: Are COMP cams junk? [Re: Kern Dog] #1662505
08/24/14 10:03 PM
08/24/14 10:03 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
I just got a Comp cam for my car. Hope it holds up!
The Mr. Sixpak cam didn't.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: Are COMP cams junk? [Re: Dixie] #1662506
08/25/14 12:19 AM
08/25/14 12:19 AM
IN
ahy Offline
ahy  Offline
IN
I run a Muscle Motors "custom" cam ground by Comp. Break-in as mentioned above and high zinc oil. No problems with ~14k miles.
Re: Are COMP cams junk? [Re: ahy] #1662507
08/25/14 01:47 AM
08/25/14 01:47 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I don't have #s, but would bet everything that Comp sells the most cams by a huge margin. Given a somewhat similar rate of failure across cam companies (for reasons including bad lifters or improper break in-- neither being CAM related), there are going to be more individuals who have had failures with comp cams. Just numbers. Maybe some people get unlucky.
I have had 100% success with 3 cams of theirs and I'm getting ready to use another. I've also run two XE284 hydraulic flat cams, and frankly I didn't notice any funny noises using an otherwise stock valvetrain.
The cam you have chosen sounds fine, don't sweat it and run it.
Re: Are COMP cams junk? [Re: ahy] #1662508
08/25/14 01:49 AM
08/25/14 01:49 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I need to quit reading these "cam horror story" posts until I break mine in I have the XE256H-10 for my 318 build. I bought it too long ago and due to life getting in the way still haven't fired it up. Is there any recourse for a failed cam after the warranty period has passed even if it hasn't been run? I understand that most of the cam failures are the more radical grinds than mine. True?(Its supposed to be what would be like stock for a 340 or 360(?))
Scott
Page 2 of 4 1 2 3 4
