Cylinder Bores #1662289
08/22/14 02:36 PM
08/22/14 02:36 PM
Here and now
jeebis44 Offline OP
jeebis44  Offline OP
Here and now
Is it possible to clean up / deglaze the cylinder bores with the heads off and the lower end still installed? Looking at doing a top-end rebuild on a tired 318 and don't want to take the engine out if I can avoid it.
Re: Cylinder Bores [Re: jeebis44] #1662290
08/22/14 02:52 PM
08/22/14 02:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's done all the time; just be sure to wrap the rod journals to keep swarf out.
Re: Cylinder Bores [Re: jeebis44] #1662291
08/22/14 04:23 PM
08/22/14 04:23 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sounds like you want to leave the pistons and rods in ??? If so the answer is NO ...
Re: Cylinder Bores [Re: jeebis44] #1662292
08/22/14 10:14 PM
08/22/14 10:14 PM
Remove SOME of the ridge with CAREFULL use of a ridge reamer (if needed). Pull dont push the cutter around the bore and changing your body position often so you are evenly pulling the cutter around the bore. Keep the tool flush with the deck (a helper is nice). It does not cut the ridge ID perfectly so do not go to flush at any point as you will likely be past the ridge/into the wall at another point. Stop & check often. Prep the bores with a brush research mfgr dingleberry flex hone with a 320 grit. get some plasma moly file fit rings. As Kunkel said protect the journals with some masking tape. Get each journal at BDC. You can soap and water scrub the bores with a minimal amount of liquid & keep it out of unwanted areas with some care & soap and water is the best way to get microscopic grit out of bored/honed cyl walls which will destroy a new ring job. Read "breakin secrets" at www.mototuneusa.com
Re: Cylinder Bores [Re: jeebis44] #1662293
08/23/14 10:23 AM
08/23/14 10:23 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I learned a new word today.
Had to Google it.
Re: Cylinder Bores [Re: Commando1] #1662294
08/25/14 11:32 AM
08/25/14 11:32 AM
ILL
MLR426 Offline
MLR426  Offline
ILL
NO, and also the use of a ridge reamer will sometimes kill a block if not used right.
MLR426
Re: Cylinder Bores [Re: MLR426] #1662295
08/25/14 12:53 PM
08/25/14 12:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
MLR426
Re: Cylinder Bores [Re: Commando1] #1662296
08/25/14 12:54 PM
08/25/14 12:54 PM
AL
jglen490 Offline
jglen490  Offline
AL
Had to Google it.
Yes, it's waht a dog does when he needs to cuss someone
Re: Cylinder Bores [Re: jeebis44] #1662297
08/25/14 01:25 PM
08/25/14 01:25 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You will have to clarify "lower end still installed"
If you mean leave the pistons and rods in it, the answer would be no as it would be pointless.
You can however drop the pan and remove the rods and pistons and then hone it and install new rings. For this you want to use plain vanilla cast rings as they will be more forgiving of bores that will obviously not be perfectly round. You can even roll new main bearings in with the rods out of it.
All that being said, unless you have no way of lifting the engine out, by the time you get enough stuff unhooked and out of the way so you can get the engine up to get the pan off and get at the rods, you're about 80% of the way to having it on the bench.
Unless it is in a Sweptline D100 or bigger truck...
Kevin
Re: Cylinder Bores [Re: RapidRobert] #1662298
08/26/14 06:23 PM
08/26/14 06:23 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Instead of soap and water use transmission fluid and paper towels. When done with honing, pour some trans fluid on a folded paper towel and wash the bores. Do this to each bore. After washing with the trans fluid, continue to wipe each bore with a clean paper towel until you stop getting residue on the towels. It is how we did it before engine assembly in the machine shop I worked in. It may take an hour or more to do it right, but you can be sure the bores are clean and there is no water getting in the engine.
