Gasser Project
#1662128
08/21/14 10:44 PM
08/21/14 10:44 PM
Posts: 1,281 WI
wannadrag
WI
Sorta in the beginning stages.I would like to run a BB mopar but nobody makes a gasser style header and not really liking the looks of a A body fenderwell header.Could say a 55-57 bb chevy fenderwell header be cut and mated to bb mopar flanges?I got the idea from a HAMB thread a fews years back and just got rolling on it a few weeks ago,41 Willys front mated to a 50 F1 ford cab.
Re: Gasser Project
[Re: 65rbdodge]
#1662131
08/23/14 04:28 PM
08/23/14 04:28 PM
Posts: 1,281 WI
wannadrag
WI
if I remember correctly bb chevy exhaust is spaced like this
0 0 0 0
bigblock mopar-
0 00 0
BUT anything could be made to fit, it just depends on how much time and skills you have.
Yup you are correct,looks like maybe a sb chevy port layout is closer
Re: Gasser Project
[Re: wannadrag]
#1662135
12/09/14 11:29 PM
12/09/14 11:29 PM
Posts: 1,281 WI
wannadrag
WI
Re: Gasser Project
[Re: wannadrag]
#1662136
12/09/14 11:31 PM
12/09/14 11:31 PM
Posts: 1,281 WI
wannadrag
WI
Re: Gasser Project
[Re: wannadrag]
#1662137
12/09/14 11:34 PM
12/09/14 11:34 PM
Posts: 1,281 WI
wannadrag
WI
Re: Gasser Project
[Re: wannadrag]
#1662138
01/26/15 01:14 AM
01/26/15 01:14 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Sweet toy. I like what you did with the square tubes on that floor. Hope you don't mind if I steal that idea.
I have mechanical Aptitude. I can screw up anything.
Re: Gasser Project
[Re: bboogieart]
#1662139
01/27/15 12:14 AM
01/27/15 12:14 AM
Posts: 1,281 WI
wannadrag
WI
Re: Gasser Project
[Re: wannadrag]
#1662140
01/27/15 12:16 AM
01/27/15 12:16 AM
Posts: 1,281 WI
wannadrag
WI
Re: Gasser Project
[Re: bboogieart]
#1662142
02/08/15 11:40 PM
02/08/15 11:40 PM
Posts: 1,281 WI
wannadrag
WI
Re: Gasser Project
[Re: wannadrag]
#1662143
02/11/15 01:56 PM
02/11/15 01:56 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
I like it! How does the cowl width on the Ford cab compare to the Willys hood? I like Ron's truck too and this seems like a fairly economical way to get that Willys style without having to find a $$ Willys first. ![](/ubbthreads/images/graemlins/thumbs.gif) What did you end up doing for headers? Kevin
Re: Gasser Project
[Re: Twostick]
#1662144
02/11/15 10:26 PM
02/11/15 10:26 PM
Posts: 1,281 WI
wannadrag
WI
I like it!
How does the cowl width on the Ford cab compare to the Willys hood? I like Ron's truck too and this seems like a fairly economical way to get that Willys style without having to find a $$ Willys first.![](/ubbthreads/images/graemlins/thumbs.gif)
Kevin
Cowl was close,i did have to round out the top corners so the hood would fit and also the half moon shape behind the hood had to be filled as the F1 hood and hinges are in that area. I also had the trim the back edge of the hood to match the curve of the F1 cowl. In order to get the front lined up with the wheel openings the cab was moved back roughly 12" and the lower cowl cut sorta moon shaped so the fenders fit into it similar to a willys. Steering column is pretty long on a F1 so I just laid it back and drilled some new mounting holes. The frame also needs to be cut flush with the front crossmember and the box needs to be cut the same amount the cab was moved back.
For headers I used sb chevy patriot fenderwell type,the port layout is close to a bb mopar. I cut the flanges off and had to spread the tubes a little to fit the mopar flanges.The raw headers are $189 and about $40 on the flanges so you have a pretty inexpensive set when done.
These builds I always have the steering done,headers done before mounting the engine so it doesn't get so involved trying to fit the headers.
Jay
Re: Gasser Project
[Re: wannadrag]
#1662145
02/12/15 02:56 PM
02/12/15 02:56 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
I absolutely love your truck and can't wait to see it done! Would have never guessed a Willys nose would fit relatively easily on a Ford F1 cab.
Re: Gasser Project
[Re: Mopar Ron]
#1662147
02/12/15 09:39 PM
02/12/15 09:39 PM
Posts: 1,281 WI
wannadrag
WI
what are your plans for the willys hood body line, on to the door?
Thinking of matching it at the front of the cowl and fading it away to the rear of it
