89 3/4 ton diesel drive train options? #1660641
08/18/14 03:38 PM
08/18/14 03:38 PM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
There is a guy fairly close to me that is selling the drivetrain out of a 1989 Dodge 3/4 ton 4x4 that had a diesel engine in it. The guy bought it just for the engine and doesn't know much about the rest of the drivetrain, he said in his email the rear axle is a dana 60 and thinks the front is too, but he's not sure and doesn't know the gear ratio. Is there a chance this truck could have a Dana 60 front axle or a NP205 t-case? Do any of you guys know what the drivetrain could be based on the limited info I have? As I get more info I will post it. Thanks!
Re: 89 3/4 ton diesel drive train options? [Re: Dennis_K] #1660642
08/18/14 03:58 PM
08/18/14 03:58 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
should be a Dana 60 front. Dana 70 rear I believe.
NP205 should also be the transfer case
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: 89 3/4 ton diesel drive train options? [Re: ViperDave] #1660643
08/18/14 04:27 PM
08/18/14 04:27 PM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
That would be cool if it were. I was looking for a 4.10 Dana 60 rear to replace the one in my 93, but if I could score a Dana 60 front and a 205 t-case, I will probably buy the whole drivetrain.
Re: 89 3/4 ton diesel drive train options? [Re: Dennis_K] #1660644
08/18/14 08:22 PM
08/18/14 08:22 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Wouldn't it also have basically a heavy duty 727 still? With a new name?
Re: 89 3/4 ton diesel drive train options? [Re: Dennis_K] #1660645
08/18/14 10:14 PM
08/18/14 10:14 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
You didn't say what tranny ( 5 speed or 727) but beware the possibility of a dana 61 front and the possibility of 3.07 gears.
Re: 89 3/4 ton diesel drive train options? [Re: jerseybud] #1660646
08/18/14 10:22 PM
08/18/14 10:22 PM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
I still haven't heard back from the guy about what trans it had. Would the 3.07 gears be in the auto or the 5-speed?
Re: 89 3/4 ton diesel drive train options? [Re: Dennis_K] #1660647
08/18/14 10:29 PM
08/18/14 10:29 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
3.07 for the auto and they are called a dana 61 and a dana 71 both manual and auto used the 205--i think the manual 205 only fits on the getrag-and the auto 205 will fit on any dodge automatic...and if it is a manual it will be a 3.54 gear---there were a few one ton 4.10 gear ratios put out there and there also were some single wheel one tons....you need to learn some more about the deal...
Re: 89 3/4 ton diesel drive train options? [Re: savoy64] #1660648
08/19/14 01:28 AM
08/19/14 01:28 AM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
The guy just sent me a text saying the truck had an auto trans, so I guess that means the axles are probably the 3.07s. Would the t-case work on a 93 NV4500 5-speed?
Re: 89 3/4 ton diesel drive train options? [Re: Dennis_K] #1660649
08/19/14 10:08 PM
08/19/14 10:08 PM
Minnesota
69Y2RT Offline
69Y2RT  Offline
Minnesota
If it has the 3.07 then that is the only ratio that will fit in the housing on the rear. T-case would need a different input shaft and the case would need to be machined to accept the larger input bearing.
(Unless the 4500 was behind a gaser then it would bolt on with out changing anything)
You would have to clearance the tail on the transmission to clear the shift linkage.
Re: 89 3/4 ton diesel drive train options? [Re: 69Y2RT] #1660650
08/20/14 12:12 AM
08/20/14 12:12 AM
SW Minnesota
Dennis_K Offline OP
Dennis_K  Offline OP
SW Minnesota
Thanks for the info. My NV4500 in my 93 is on a 5.9L gas v8 magnum. I already told the guy he probably doesn't have anything I can use, but maybe I should ask him what he wants for the t-case.
Re: 89 3/4 ton diesel drive train options? [Re: Dennis_K] #1660651
09/05/14 04:41 AM
09/05/14 04:41 AM
Hawley, Texas
shinnery Offline
super street
shinnery  Offline
super street
Hawley, Texas
If it wasn't so far away I would love to have that complete Dana 71 to put in my 92 CTD 4x2 w/A618 to make a hiway cruiser. Been thinking' of cuttin' about 18" out of the chassis and puttin' a 88 Ramcharger body on it.
Bryce
Every electronic device is manufactured with smoke stored deep inside... only a true genius can find a way to set it free. The most terrifying words in the English language are: "I'm from the government and I am here to help!"
