97 Dakota A/C question-where does it get power?
#1659894
08/16/14 10:51 PM
08/16/14 10:51 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
97 Dakota 4WD 318/auto
Where does the compressor clutch get its signal/power to engage?
I am thinking it from the computer through the low pressure switch then high pressure switch finally to the clutch. Is there a WOT relay on those? I have already swapped the power relay and tested for power back to the low pressure switch with no power (using a test light).
Can I jump the clutch and coil with straight power to test it? I am assuming the system is grounded and gets a power/positive signal to engage.
Thanks in advance, Kevin
Careful, your character's showing!
Re: 97 Dakota A/C question-where does it get power?
[Re: ademon]
#1659896
08/16/14 11:02 PM
08/16/14 11:02 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I've heard rumors of a "WOT cut-off switch" but there is no physical switch. If any such switch or feature exists, it's all in the programming of the PCM, since the signal for the clutch ultimately originates from within the PCM.
**Photobucket sucks**
[Re: 383man]
#1659902
08/17/14 09:54 PM
08/17/14 09:54 PM
mopar346
Thank you, today's PCM swap (known good from one of my other trucks, actually the original from this truck that the cruise circuit felled on a year or so back, but the A/C circuit is fine) didn't cure it and I really didn't have time to diag it so it will wait til next week end.
[Re: mopar346]
#1659903
08/28/14 08:39 PM
08/28/14 08:39 PM
mopar346
So I finally got back to it and what I found was no power to the relay (it was there on my 99 wioth either computer), it gets the trigger when the A/C is turned on but no constant power to it. I don't see any fuse in the circuit and when I pulled the PDC I found no obvious burnt wires. So in an effort to further diag it I ran a power wire to it and it engaged and everything worked properly for about 2 moinutes then is melted my bypass wire which was fairly small gauge (on purpose). I then wired the relay outside the box with a fuse on the power wire, it worked fine until I engaged the clutch and then it popped the fuse. So to me the clutch is shorted or has high resistance anyway. I'll swap it out to test and see if everything else is OK. So I have 3 questions, first is there a fuse in the system I am overlooking, second where does the power to relay come from and finally is it a 12 volt feed.
[Re: mopar346]
#1659904
08/28/14 09:59 PM
08/28/14 09:59 PM
Posts: 1,728 ST clair shores MI
moretoys
ST clair shores MI
yes, there are 2 fuses.(before the relay, nothing after) If they are not labeled, use a test light and with ign on, check all fuses for power on both sides. if test lights only lights up on 1 side of the fuse, it is blown. typical relay uses 4 wires. 1 constant 12v power, 1 ignition 12v power, pcm controls ground circuit, output to the device.
[Re: moretoys]
#1659905
08/28/14 10:38 PM
08/28/14 10:38 PM
mopar346
Thank you, I didn't test the fuses cause they are all labeled for other devices and I haven't noticed anything else not working but it's cheap and easy to test them just to be sure. It is a 5 pin relay by the way but not sure what the fifth leg is, but I beleive you are correct on the 4, I was jsut making sure it wasn't a reduced constant power. I should have time to do some more testing tomorrow and will update.
[Re: mopar346]
#1659906
09/06/14 10:09 PM
09/06/14 10:09 PM
mopar346
Well I finally got back to it today and finished it. The clutch was shorted and that was blowing the fuse. I did finally locate the fuse with the test light, it was in the power distribution box cleverly labeled A/C Clutch, don't ask me how I missed it, I will just amuse I'm an idiot. Once I fixed that I removed my wiring harness I built to supply fused power out side the boxa dn returned it to the factory set up, works like a champ. Just thought I would close the thread.
Thanks for the help folks!
