edelbrock performer rpm install on a 440?? #1659556
08/16/14 01:23 AM
08/16/14 01:23 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
helping a friend install a performer intake on a 440.according to the instructions u use the valley pan and then add edelbrock gaskets on the intake side.do u guys use sealant on the front and back of the valley pan?do this sound right.thanks
Re: edelbrock performer install on a 440?? [Re: hp340nos] #1659557
08/16/14 01:37 AM
08/16/14 01:37 AM
Kirkland, Washington
Pacnorthcuda Offline
At the very least you use a dab of sealant at the four corners where the heads meet the block at the intake area. I also use sealant at both ends, but NOT on the intake surface itself (around the ports).
As far as adding extra gaskets, I add them as space allows (often there is no room for them and still be able to start the intake bolts). If there IS room, I like to super glue the gaskets to the valley pan to ensure they don't walk.
Re: edelbrock performer install on a 440?? [Re: hp340nos] #1659558
08/16/14 02:49 AM
08/16/14 02:49 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
After much trial and error, I ended up w/two of the thin gaskets one on each side of the tray held in place w/Gaskasinch, silicone on end rails all the way across and silicone on the intake bolts since they see oil. Of course this is AFTER making sure the manifold doesnt need a kiss or two to make it fit properly w/gaskets and tray thicknesses........
Re: edelbrock performer install on a 440?? [Re: hp340nos] #1659559
08/16/14 04:37 AM
08/16/14 04:37 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
You swapping an RPM onto this 440? Standard performer isn't worth bothering with, unless it's a completely stock engine, IMO.
Re: edelbrock performer install on a 440?? [Re: Thumperdart] #1659560
08/16/14 05:00 PM
08/16/14 05:00 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
This is the only way I got mine to finally seal. I didn't put silicone on the bolts but in my defense I didn't know any better. No leaks though.
I am running a performer RPM on aluminum Mopar heads.
Re: edelbrock performer install on a 440?? [Re: Joshs68] #1659561
08/16/14 05:24 PM
08/16/14 05:24 PM
Califor-ni-A!
MrFoFody Offline
MrFoFody  Offline
Califor-ni-A!
Just the pan ( no gaskets on ports) with sealant on the valley ends
Re: edelbrock performer install on a 440?? [Re: MrFoFody] #1659562
08/17/14 01:38 AM
08/17/14 01:38 AM
Elizabethton Tn
louie heaton Offline
Elizabethton Tn
I had lots of trouble with mine, what worked for me too , was just the valley pan, no gaskets. This was with stock casting heads,one of the last sets Herb McCandless sold out of his shop I got years ago, using a performer RPM. Motor was built by Matt Hensley, it has been a great motor. Could run faster, but can't get it to hook with the 4.10 Dana and that's using first gen BFG 325X50 15's drag radials.
70 T/A clone, Hensley built 440,(not much more than stock) Low 12's at Bristol,(17 miles from here)8 other various Mopars, used to have 800+ posts back around 2001.
Re: edelbrock performer rpm install on a 440?? [Re: hp340nos] #1659563
08/17/14 02:05 AM
08/17/14 02:05 AM
Way North Idaho
1KoolBee Offline
1KoolBee  Offline
Way North Idaho
Before you get too far with the install, make sure the intake and head mating surfaces are machined to matching angles. You can tell by setting the intake on the clean heads with no gaskets, make sure its setting as evenly on the heads as possible and running a feeler gauge around all of the ports. If anything over about .005 will fit between intake & head, you'll have to get the manifold angle corrected or get real creative with paper gaskets. I ran into this on my 383 & had vacuum leaks no matter what I did. Had a local machinist square it up, & it seals great with super thin paper gaskets on each side of steel tray. The 383 had stock heads, interestingly enough, my 500 motor with edelbrock heads fit perfect right out of the box.
'68 Bee 383/TF/Factory Air...high school sweetheart
'67 GTX Clone project,500 six pack,Hemi4-speed,Dana
05 Dodge Viper, 505 V-10, 6-speed Tremec
Re: edelbrock performer rpm install on a 440?? [Re: 1KoolBee] #1659564
08/17/14 01:56 PM
08/17/14 01:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This is the long version but the proper way...............saved me some serious typing.
