68 Barracuda fastback rear window moulding question.. #1659122
08/14/14 10:11 PM
08/14/14 10:11 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
So I am trying to figure out how the piece of interior trim, the curved piece that goes directly under the rear window, attaches. Its like its supposed to screw into air, and I don't think that's what Mopar intended. Does it take some sort of spacer to make it to the rear window channel? I am almost ready to install the back window, which I hear is a pain, but need this in place first. Any good tips or tricks to make the rear window install go smooth would be awesome as well..
Thanks !
Dave in Colorado
Re: 68 Barracuda fastback rear window moulding question.. [Re: dssaa] #1659123
08/15/14 10:15 AM
08/15/14 10:15 AM
Middletown , Ohio
DonnieLawson Offline
Middletown , Ohio
there are small plastic spacers that attach there , I cant find any pics of mine.... they fit between the trim and body
Re: 68 Barracuda fastback rear window moulding question.. [Re: dssaa] #1659124
08/15/14 09:21 PM
08/15/14 09:21 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Here is a shot from underneath
Re: 68 Barracuda fastback rear window moulding question.. [Re: DUSTER_340] #1659125
08/15/14 09:24 PM
08/15/14 09:24 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Picture of the side
Re: 68 Barracuda fastback rear window moulding question.. [Re: DUSTER_340] #1659126
08/15/14 09:29 PM
08/15/14 09:29 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Here is the left rear corner
Re: 68 Barracuda fastback rear window moulding question.. [Re: DUSTER_340] #1659127
08/15/14 09:31 PM
08/15/14 09:31 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Right corner/middle
Re: 68 Barracuda fastback rear window moulding question.. [Re: DUSTER_340] #1659128
08/15/14 09:33 PM
08/15/14 09:33 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
Close up of retainer nut
Re: 68 Barracuda fastback rear window moulding question.. [Re: dssaa] #1659129
08/15/14 09:41 PM
08/15/14 09:41 PM
Armada MICH.
DUSTER_340 Offline
DUSTER_340  Offline
Armada MICH.
As far as installing it, I would start at the bottom of the window setting that into the seal, that is already installed on the body. Then work the window up the sides both left and right towards the top of the glass and finish with flipping the top part of the seal over the glass last. When I removed mine I started with the upper corners, worked a little down the sail and across the roof, working side to side. Finishing at the bottom, don't forget to use some bedding/glazing material in the weatherstrip to seal the rubber to the glass, go slow and use nylon sticks to help work the glass into the seal.
Re: 68 Barracuda fastback rear window moulding question.. [Re: DUSTER_340] #1659130
08/15/14 10:15 PM
08/15/14 10:15 PM
Colorado
dssaa Offline OP
dssaa  Offline OP
Colorado
Awesome, pics help a lot. Now where do I find those spacers? Time to start the search... Thank you so much!
Dsve
