'01 Ram replacement headlights #1657931
08/11/14 11:37 PM
08/11/14 11:37 PM
central IL reg Nov 18, 1999
Stroker Offline OP
Stroker  Offline OP
I've been looking for replacement headlights online for my 2001 2500 Ram Sport. No euros, halos, or projectors needed.
Are the Dormans Ok, or are they offshore junk?
Just looking for something good -and clear - that doesn't cost an arm and a leg.
My turn signals look like new, btw.
Re: '01 Ram replacement headlights [Re: Stroker] #1657932
08/11/14 11:45 PM
08/11/14 11:45 PM
Ontario, Canada
D149 Offline
D149  Offline
Ontario, Canada
I just bought a pair of sport headlamps from LMC Truck for my 2001 Ram. I installed them this past week and they fit exactly like the original lights. I haven't driven the truck at night yet to see how well they work, but they seem just like stock. They are made overseas.
I got the entire headlamp including signal for $149.95 ea. They also have just the headlamp without the signal for a cheaper price.
Just one of the many options for headlights I found.
1968 Valiant Signet 4dr. 273 4spd
1969 Road Runner 383 4spd
1969 Barracuda 318 auto
1970 Dart Swinger 340 4spd
1975 Cordoba 400-4bbl
1988 Caravelle 318 Auto
1999 Dakota R/T
2000 Viper GTS
2001 Ram 2500 Diesel 6spd
2018 Dodge Challenger GT (Winter beater!)
Re: '01 Ram replacement headlights [Re: Stroker] #1657933
08/12/14 12:21 AM
08/12/14 12:21 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
The Sport headlights are more expensive than the std headlights, but the std ones can be made to work if you have access to a salvage yard for a few necessary pieces to make the conversion work.
Are your headlights just cloudy? If that is the issue, you can get them fairly clear again by sanding with some 1000 grit and spraying with clear coat. Works real well and keeps the yellow and clouding from coming back as soon.
Or you can just spring for a new set.
Master, again and still
Re: '01 Ram replacement headlights [Re: DaveRS23] #1657934
08/12/14 10:45 PM
08/12/14 10:45 PM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
I bought a pair of Depos from Amazon for my '02 Sport. They fit well and ran around $100 each.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: '01 Ram replacement headlights [Re: Stroker] #1657935
08/13/14 06:17 PM
08/13/14 06:17 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Look on Ebag..I bought set for my 02 Ram and I paid $80 for both.Yes they are China made,but they work great.
Nautilus Racing-
