Re: HELP - 2009 SRT8 Challenger won't stay running
[Re: 69dart]
#1657751
08/12/14 01:34 AM
08/12/14 01:34 AM
Posts: 4,941 WI
Dcuda69
WI
I think those sensors would trip a an obdII code.
Did you scan it? Remember, it's very possible for OBDII to see an issue and not turn on the light. Some circuits/sensors need 2 consecutive trips with a fault to flag the light....however a code can still be in the PCM,it's called a pending code. Have it scanned for ALL codes and look closely at data. Any competent service center should be able to help you out.
P.S. Make sure they check for relevant TSB's while they have it.
[Re: feets]
#1657756
08/12/14 02:08 PM
08/12/14 02:08 PM
Posts: 21,063 Niles , Ohio
therocks
Niles , Ohio
One reason they make scanners.Never amazes me that people will spend tons of $$$$ guessing at a problem.But wont spend say 80 bucks for a diag.Saw it at thw shop a lot.The parst store says it this or that.They spend $$$ and same problem.Scanners read live data.Code readers dont.Rocky
Chrysler Firepower
[Re: floridian]
#1657758
08/12/14 05:17 PM
08/12/14 05:17 PM
Posts: 25,726 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I was thinking fuel filter too.
[Re: Sxrxrnr]
#1657760
08/12/14 10:01 PM
08/12/14 10:01 PM
therocks
Niles , Ohio
Just google TSBs and recalls.It lists pretty much all of them.That car has a module pump.Ive never seen one yet that the filter inside was plugged and I worked on all of them for over 30 years.Rocky
Chrysler Firepower
[Re: 69dart]
#1657763
08/13/14 01:30 PM
08/13/14 01:30 PM
Posts: 43 League City, TX
BlueGhost
League City, TX
Did the problem get worse after you filled the tank?
I have a 2006 SRT8 Magnum. If I top the tank off the car will buck and stall. The problem is with a valve on the top of the gas tank. It lets raw fuel into the evap system when the tank is full/overfull, then when the evap opens it dumps raw fuel and floods the car.
The first time this happened to me I filled up on a slow pump and by the time the pump kicked out my tank was past topped off. So far I've just been stopping at just over 3/4 full when I get gas, and haven't had anymore stalling problems. I got a letter form Chrysler, the problem is so common that they are extending the warranty on the tank and will replace it for free. I just haven't brought mine in yet.
I know this affects Magnums, Chargers, and 300s, but I'm not sure about Challengers or the specific year models.
1958 Plymouth Suburban
