Re: 650 hp low 10s high 9s fuel systems what's in your car
[Re: RAY1969CARS]
#1656254
08/09/14 03:53 AM
08/09/14 03:53 AM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I just pulled a BG400 pump from my BrandX as it ate itself. -10 line. No interest in fixing it. I replaced it with a QuickFuel 230 pump. I have a 498 that is around 650hp, it went 9.40 @ 139mph in a 2600 pound BrandX. Mine weighs 3000-3100 and not as good a chassis so I will slow down from those numbers for sure.
CrAzYMoPaRGuY
[Re: RAY1969CARS]
#1656255
08/09/14 02:08 PM
08/09/14 02:08 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
My system is plumbed for a BG 220 HR. That pump seized after about 4 1/8th mile passes and 10 street miles. I replaced the pump with a Mallory 250, using the same plumbing. -10 to BG filter mounted on the Mallory pump , -8 to BG regulator and Race Demon 1050 carb with -10 return line. I have only run 1/8th mile with the car. Best so far 6.00 @ 115.27 MPH 1.38 60ft. Mark ![](/ubbthreads/images/graemlins/thumbs.gif)
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: cudadoug]
#1656258
08/09/14 04:39 PM
08/09/14 04:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Remember that E-85 requires 30% more flow over gas.. I run dual pumps just because I had them.. I didnt want to chance running lean on a single(it would have been close) ![](/ubbthreads/images/graemlins/wave.gif)
[Re: JAKE68]
#1656260
08/09/14 07:42 PM
08/09/14 07:42 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
20 year old Holley blue pump 3/8 aluminum fuel line Chrome Holley dual feed steel line thingy to the bowls. (No I'm not kidding) 30 year old Holley 800 DP 3/8 standard fuel filter
10.14 @ 128 best, 416 Duster @ 3100#
-06 lines from reg to bowls it ran the same. -08 lines to the bowls...ran the same.
I once made many a 10.30 run on another combo and I thought it was time to rebuild my many runs old Holley blue pump. A buddy talked me into trying his BG trick, billet cement mixer pump. Guess what? Car ran exactly the same with the BG pump and regulator.
While I agree that you can't have too much fuel, I believe this is an area that guys over spend on to go low 10's/high 9's...or faster! Where is the guy from NJ that had the old S/G Cuda that went 8.90's with a 500" B1 and a single blue pump?? That was one of the first fuel pump debates I read here.
Some of you may recall the mid 80's, 500" Pro Stocks going in the 7's with Holley blue pumps and those "junk" deadhead regulators, right?? They did...because that's all there was...LOL!
I AGREE
Same here....running as good with the same set up !
[Re: cudadoug]
#1656262
08/11/14 02:12 PM
08/11/14 02:12 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
The pro comp 140 pump is the exact same as the Holley black. I had a leaky gasket on my Pro comp and put a Holley kit in it. It worked fine it was just dripping a little out of the plate on the bottom so I put a kit in it. I think this pump was $40 off ebay. I just cant believe it still works. I was running a 440 that ran low 12's in a 4000 lb ram and sprayed it 150 nitrous and pump stilled kept up.
67' charger 499 RB
10.57 at 127
[Re: Blucuda413]
#1656264
08/11/14 04:10 PM
08/11/14 04:10 PM
Posts: 1,178 Indy
FlyFish
Indy
Mine's mid 10's on e85, Holley Black pump, Holley 40 micron steel mesh filter after the pump, 1/2 line up to the home made 750dp carb, works great.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
[Re: FlyFish]
#1656265
08/11/14 09:30 PM
08/11/14 09:30 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Bob Glidden used to run two Holley Blue pumps in pro stock.....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
