Page 1 of 5 1 2 3 4 5
ProMaxx Performance 440 heads #1654594
08/03/14 07:16 PM
08/03/14 07:16 PM
Alabama
Y
young guns 90s Offline OP
Y
Alabama
any buddy use ProMaxx Performance 9440 - ProMaxx MAXX Series Big Block Chrysler Aluminum Cylinder Heads Details
Big Block Chrysler 210cc/295+ CFM Additional Cylinder Head Specifications
Valve Angle: 15° Valve Seal Material: Viton Spark Plug Type: Angled Retainer Material: Steel Maximum Spring Lift: .600" Hydraulic Flat Tappet think about use them on 66 440 factory steel crank factory steel rods lighten polish with JE or ROSS pistons full floating pins
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1654595
08/03/14 09:20 PM
08/03/14 09:20 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Looks a lot like Edelbrock Performer RPM 440 head. I wonder if it's just Promaxx working a set of the sidewinder castings?
Re: ProMaxx Performance 440 heads [Re: GTS340] #1654596
08/03/14 09:31 PM
08/03/14 09:31 PM
Alabama
Y
Y
Alabama
i have no clue i know heads are standard port flow at 295 cfm on intake side for price cant beat it better then 440 source heads
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1654597
08/03/14 09:38 PM
08/03/14 09:38 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
Really? From where? I thought Jegs had them priced very similar to the Edelbrock.
Re: ProMaxx Performance 440 heads [Re: GTS340] #1654598
08/03/14 09:51 PM
08/03/14 09:51 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i'm not certain but looked around a little bit and am inclined to believe they're imported castings, i could be wrong. that said if they are imported for that money i'd pony up the rest and buy a USA made head but that's just me. they actually cost more than the 75cc e street heads with the racer discount
Re: ProMaxx Performance 440 heads [Re: jamesc] #1654599
08/03/14 09:55 PM
08/03/14 09:55 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
You have a PM
Re: ProMaxx Performance 440 heads [Re: GTS340] #1654600
08/03/14 10:20 PM
08/03/14 10:20 PM
jamesc Offline
jamesc  Offline
You have a PM
so do you
Re: ProMaxx Performance 440 heads [Re: jamesc] #1654601
08/03/14 10:29 PM
08/03/14 10:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have no pm.
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1654602
08/03/14 10:33 PM
08/03/14 10:33 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
how could you possibly know this without running them?
Re: ProMaxx Performance 440 heads [Re: GTS340] #1654603
08/03/14 10:49 PM
08/03/14 10:49 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Promaxx doesn't buy castings from the guys selling Sidewinder heads, that much I know.
RPM heads and Stealth heads both flow much less than advertised on a calibrated bench. Sidewinder heads will out flow those two castings out of the box.
I don't know how these Promaxx compare
Keith
Re: ProMaxx Performance 440 heads [Re: Dunnuck Racing] #1654604
08/04/14 12:39 AM
08/04/14 12:39 AM
tn
robnbird Offline
robnbird  Offline
tn
Keith
where can they be bought .
Re: ProMaxx Performance 440 heads [Re: robnbird] #1654605
08/04/14 12:55 AM
08/04/14 12:55 AM
Northern Indiana
Northern Indiana
The Sidewinder heads can be bought through Todd at CompWedge Engines, or I can get them. There are a couple other builders selling them also . They really are a nice part .
I have a build in the works with a set now. More consistent port shape and size when compared to other brands I have used.
Keith
Re: ProMaxx Performance 440 heads [Re: Dunnuck Racing] #1654606
08/04/14 01:15 AM
08/04/14 01:15 AM
tn
robnbird Offline
robnbird  Offline
tn
Keith
how are these compared to the Eddy victor max wedge ?
Re: ProMaxx Performance 440 heads [Re: robnbird] #1654607
08/04/14 01:19 AM
08/04/14 01:19 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Guys as far as I know the Promax and the sidewinder are the same casting. Robin they will not touch a Victor. These are much more akin to the RPM. Todd
Re: ProMaxx Performance 440 heads [Re: sasquatch] #1654608
08/04/14 01:43 AM
08/04/14 01:43 AM
tn
robnbird Offline
robnbird  Offline
tn
OK thanks Todd , I am going to order the eddy max wedge tomorrow but going to use the Indy 400-3 intake .
Re: ProMaxx Performance 440 heads [Re: Dunnuck Racing] #1654609
08/04/14 01:22 PM
08/04/14 01:22 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
A truer statement on Moparts I have not heard
Re: ProMaxx Performance 440 heads [Re: GTX MATT] #1654610
08/04/14 02:44 PM
08/04/14 02:44 PM
dogdays Offline
dogdays  Offline
Remember a few years ago, a new US cylinderhead company called Patriot? They staked out the lower edge of the smallblock chevy market, made a decent aluminum head which got a lot of press because it was good but inexpensive.
Somewhere along the way they were bought and renamed as ProMaxx.
As their sbc and sbf heads were pretty good, I would guess that their BBM heads would be good too.
R.
Re: ProMaxx Performance 440 heads [Re: young guns 90s] #1654611
08/07/14 11:08 PM
08/07/14 11:08 PM
Way out in the sticks of Weste...
DusterDog Offline
DusterDog  Offline
Hey Kenny,
I sent you a PM!!!!!
"I've upped my horsepower, so...... UP YOURS!!!"
Re: ProMaxx Performance 440 heads [Re: DusterDog] #1654612
08/08/14 02:29 AM
08/08/14 02:29 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
So...are these gonna stick around longer than the BullDog heads?? Or just the next flash in the pan.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: ProMaxx Performance 440 heads [Re: MoparBilly] #1654613
09/17/14 10:30 PM
09/17/14 10:30 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
So I take it no one has tried these ProMaxx heads like the op was asking?
