Page 2 of 3 1 2 3
Re: Wheel Stud Spinning Can't Get Nut Off [Re: burdar] #1651753
07/28/14 06:01 PM
07/28/14 06:01 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Is the rear end an 8 3/4? If not, can you just pull the axle?
How would you gain access to the five bolt axle flange with the wheel and rotor in front of it ?
Re: Wheel Stud Spinning Can't Get Nut Off [Re: formula_s] #1651754
07/28/14 07:40 PM
07/28/14 07:40 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Die Grinder time, with a carbide bit.
One of these, or similar tool.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651755
07/28/14 08:25 PM
07/28/14 08:25 PM
Pa. U.S.A.
moparborn Offline
moparborn  Offline
Pa. U.S.A.
Put 2 other nuts loose on opposite the bad one and lower some of the weight of the car down on it to pin the stud tight.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: formula_s] #1651756
07/28/14 08:29 PM
07/28/14 08:29 PM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
simple...you need to REMOVE the wheel....and that's where we are stuck
Re: Wheel Stud Spinning Can't Get Nut Off [Re: terzmo] #1651757
07/28/14 08:49 PM
07/28/14 08:49 PM
McGregor,Iowa 52157
500ciDuster Offline
500ciDuster  Offline
McGregor,Iowa 52157
He said it had disc brakes, I wonder if there is any clearance to maybe do something like putting a welding rod in to give it a little tack weld?
Re: Wheel Stud Spinning Can't Get Nut Off [Re: moparborn] #1651758
07/28/14 08:54 PM
07/28/14 08:54 PM
KY
Telvis Offline
Telvis  Offline
KY
That's King Weenie to you!
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Telvis] #1651759
07/28/14 09:45 PM
07/28/14 09:45 PM
Central TX
roe Offline
roe  Offline
Central TX
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Wheel Stud Spinning Can't Get Nut Off [Re: roe] #1651760
07/28/14 10:00 PM
07/28/14 10:00 PM
Ontario,Canada
brads70 Offline
brads70  Offline
Ontario,Canada
"IF" it just not seated and there are still splines left, try welding a length of threaded rod on the nut and using a slide hammer try and seat the stud? Put two nuts on the threaded rod first just in case it works so you can jam them together to turn off the nut. If it's all stripped and/or wallowed out this won't work though.
Just a thought?
Re: Wheel Stud Spinning Can't Get Nut Off [Re: brads70] #1651761
07/28/14 10:19 PM
07/28/14 10:19 PM
Canton, Ohio
Crazy68Dart Offline OP
Canton, Ohio
Thanks for all the ideas. However, still nothing.
I just attempted a slide hammer with a steel bar across the two spokes spanning the nut. Hoping to pull the stud into the flange. No go. Didn't want to beat on it to hard afraid of damaging the wheel. Already started to curl the edge a little. Nothing a file and some polishing won't fix.
The issue with putting the weight of the car on it is that the nut is on so far that it is into the taper of the wheel. So it is not loading the stud, but rather the nut on the taper. Regardless, I tried this, and still no go. Effing thing.
Bout all I can see working is drilling it out. Have to figure out a way to make a good pilot into that key nut, and pray that I don't bust the bit off.
Either that or take a sledge to the car and call the scrap company. Sorry, bad day.
383, Hemi 4-Speed, AlterKtion, D60
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Crazy68Dart] #1651762
07/28/14 11:16 PM
07/28/14 11:16 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
drill it..I did it on my sons srt-4
Re: Wheel Stud Spinning Can't Get Nut Off [Re: AARCONV] #1651763
07/29/14 02:47 AM
07/29/14 02:47 AM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Have you tried bouncing any ideas off anybody at tire store? I would imagine someone has run across this problem before and had a pretty good method of solving his problem without damaging the wheel - specially with all the aftermarket/alloy wheels on cars these days...
Good luck with it.
On mine, I was able to put 3/4" box end wrench (on which I had to remove half of the wrench to get it into the well of the wheel itself between the spokes [AR 200S wheel]) on the nut to keep it from spinning. Then starting drilling (and grinding) (and taking time off for sanity). 3 days later it was off.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: MoparMarq] #1651764
07/29/14 10:45 AM
07/29/14 10:45 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Read what I wrote...
I said if it's NOT an 8 3/4, can you remove the axle?
Re: Wheel Stud Spinning Can't Get Nut Off [Re: burdar] #1651765
07/29/14 02:31 PM
07/29/14 02:31 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Most of the time you can take a punch and drive the middle nub of those lock nuts all the way through into the space between the top of the stud and the top of the nut. That would let you start a drill with less trouble. We used to do that at used car lots so you could use a 3/8 or 1/2" extension as a key to remove the lock nut if you didn't have a key.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: hemi71x] #1651766
07/29/14 02:50 PM
07/29/14 02:50 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I make carbide burrs in all shapes sizes and different cuts. Let me know what size shank you need and I'll make you up a cutter.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Pynzo] #1651767
07/29/14 02:52 PM
07/29/14 02:52 PM
NO RUST IN AZ!!!
azmopar Offline
azmopar  Offline
NO RUST IN AZ!!!
dry ice and a punch works great too
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: Wheel Stud Spinning Can't Get Nut Off [Re: azmopar] #1651768
07/29/14 03:11 PM
07/29/14 03:11 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
Tack weld a nut to the lugnut or cut it off carefully and replace.
I recently had a similar situation where I used a cutoff wheel on my grinder and cut through the center of the lugnut and lug stud. The stud is easy enough to replace. You may not have as much room with your wheels as I did.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Soopernaut] #1651769
07/29/14 03:14 PM
07/29/14 03:14 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Put a couple lugs back on semi-loose. Lower the wheel to touch the ground and to put pressure on the stud to hold it. Try and put the loose stud at the 6 o'clock position. even though the wheel may be hub centric it should put enough pressure on it to hold it. be careful and use an impact to zip the lug off.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Telvis] #1651770
07/29/14 05:30 PM
07/29/14 05:30 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
This and the impact should be enough, to get this finger tight nut off.
Re: Wheel Stud Spinning Can't Get Nut Off [Re: Sport440] #1651771
07/29/14 11:16 PM
07/29/14 11:16 PM
Freeport IL USA
poorboy Online content
poorboy  Online Content
Freeport IL USA
So many people are suggesting things he has already tried. read the thread before you post.
Knock the center out of the locking lug, and drill out the stud. I have removed several screwed up lug nuts this way. Start with a new 1/8" bit at the center of the stud and drill all the way through the stud. Then step up to 1/4" drill bit, again drilling all the way through, then use a 3/8" bit, drill all the way through. If your still centered on the stud, hit it with a 7/16 or a 1/2" drill bit. At some point, the nut will fall off.
When you get it apart, be sure to check the condition of the other studs, if 1 failed, the others can't be much better. Fix the problem before you get to do this with all the lug nuts. Gene
Re: Wheel Stud Spinning Can't Get Nut Off [Re: poorboy] #1651772
07/30/14 12:51 AM
07/30/14 12:51 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I read where he said he tried that. But, if not done correctly you can have a failed attempt.
This nut was finger tight, if done correctly the suggested fix should work easily. Just trying to emphasize that.
68Dart, Im pretty good at stuff like this, PM me and I will help you with it. Im in canton, myself by the HOF
Page 2 of 3 1 2 3
